Car wanted for photo shoot
Re: Car wanted for photo shoot
Ian. I assume it's for the 25th annerversery of the XM.
Shame you couldn't get up this way. My land lord has a nice H reg SED 2.1 manual. Nice early car.
so we should see a nice accurate report then with no errors on time line production?
for example lh displays always work on series one cars but regularly fail on s2 cars they are not cross compatible either but they are now repairable..
Yes, nothing but the truth and no inaccuracies please!!!. I will be quite interested to see if there will be a little spike in interest from people wanting one when it hits the selves.
I can't give too much away about the feature - you'll have to wait! It features lots of cars, so there won't be huge volumes of text. I'll cram in what info I can. I'm particularly keen to know how much suspension travel you get at the front. Does anyone know? Bump stop to bump stop.
1986 2CV6 Dolly, 1980 Dyane
Sorry I know im not meant too, but hoping its a 90's excecutive car group test.... this is my guess. I know...wait till its published!!
Your guess is not correct.
Oh well!dollywobbler wrote:Your guess is not correct.
Citroen reckon that 18 cm is the minimum necessary for a smooth ride, so I would think that is a bout right...but...I'll go and measure minimum to maximum height right now.dollywobbler wrote:I can't give too much away about the feature - you'll have to wait! It features lots of cars, so there won't be huge volumes of text. I'll cram in what info I can. I'm particularly keen to know how much suspension travel you get at the front. Does anyone know? Bump stop to bump stop.
I've just been out to measure and make it 12cm, which doesn't seem a lot. Can someone else measure as well, please.
If its a group test I HOPE DAMM WELL Theres a Renault 25 in the group! Else I will be disapointed!!
Mine work, but the lamp warning box must have got confused because it displays left then right tail lamps blown instead of press brake pedal to test lamps, on initial start.citroenxm wrote:
Not sure what happened, it just started doing it.
