Near side wheel-arch liner
Post by Dieselman » Sat Dec 28, 2013 3:30 pm
I need a new front arch liner as mine has met a sticky end.
Re: Near side wheel-arch liner
Post by CitroJim » Sat Dec 28, 2013 3:33 pm
Did you run over a tube of glue Will?
Post by Dieselman » Sat Dec 28, 2013 4:30 pm
No. The inner wing needed a small patch and the liner set on fire and was properly ablaze and dripping plastic. I tried to blow it out but it was a bit fierce for that, so I soaked a towel and used that to smother the flames.
If anyone has some spare hand skin that would be good too...
Post by CitroJim » Sat Dec 28, 2013 5:04 pm
So easily done though Will, I had a lovely wheelarch fire on a Xantia a while back when using the hot spanner to help release a rusty Activa ram union. The LHM leaking from the loosening union caught and burned like a good 'un
Only last week I nearly set my workshop alight practicing with a mig welder I now have in my possession..
Post by Dieselman » Mon Dec 30, 2013 10:58 am
Bump.
