citroenxm wrote:TOLD YOU TOLD YOU - na na na na na...CitroJim wrote:
I still think the S1 dash is cooler than a cool thing...
Cooler than an S2 one that's for sure...
Gold 2.0Si
Re: Gold 2.0Si
Re: Gold 2.0Si
I don't recall a coolant level checker from my early Si, it just had the normal gauges, Revs, Speed, Temp, Fuel, Oil level.robert_e_smart wrote:There is no oil pressure gauge. But a coolant level checker. Its on a needle, and the oil level is a back lit visual level type marker.
Re: Gold 2.0Si
so oil level ..backlit gauge thing.....oil pressure ....the needle that pops up and back to rest.
Ha ! Jim a confession.... Mk1 dashes are superior!
Re: Gold 2.0Si
NO OIL PRESSURE GUAGE!
Just oil pressure LIGHT! and oil level guage...
Re: Gold 2.0Si
One day this will sink in! So the light is pressure, the gauge ...oil level.
Good. sorted. That all makes perfect sense, I think!
Re: Gold 2.0Si
Yaay.... It lights up to get your attention... oil level is rather important for a long engine life..
Re: Gold 2.0Si
YES...Got it!!!!!
that is a very obvious point Paul. d'oh!
Re: Gold 2.0Si
No. When the gauge illuminates, it is reading the oil level.russ92xmsed wrote: One day this will sink in! So the light is pressure, the gauge ...oil level.
There is no visible oil pressure warning unless oil pressure is lost, at which point the dot matrix says low oil pressure, the main warning cluster illuminates the STOP light.
Re: Gold 2.0Si
I know I just wish there was an S1 ES9 V6.. Trouble is, the engine and gearbox I love so much is just not available with the dash I loveruss92xmsed wrote: Ha ! Jim a confession.... Mk1 dashes are superior!
