CCC National Rally - 20/21 July 2013.
- Orga / RP numbers: 8542
Re: CCC National Rally - 20/21 July 2013.
It says on Wicksteed Pk's own website, on the camping sub menu, that all booking must be made in advance and paid via debit/credit card. Whether they would actually turn anyone away is another matter. It does seem to be the ( camping ) industry standard though these days.
Mark Smith.
1997 Honda Firestorm.
Just hope it doesn't catch anyone out Mark...
Looks like a plan has come together for the National - setting off early on Sunday Morning in convoy which I believe will be S1 XM 24v, C4 and S2 XM 24v...
Don't wake us up too early Franklin.
Mark Smith.
Won't be too early Mark - about an hour from here.
Less if the road's clear...
Apparently the bottom of the campsite has a railway line running alongside it and every morning an oil tanker train runs along it at 03-30 and makes a hell of a racket!! So if you're not a insomniac trainspotter you might want to pitch up at the other end.
Mark Smith.
Don't forget to bring plenty of sun cream!!
Mark Smith.
- Aerodynamica
Anyone going to be bringing a sphere pressure tester and/or re gassing gear?
1993 Xantia 1.9 TD VSX 'Auld Katy' Mk1 'sinker'
No, but I've found your camping pot Graeme. Remind me to hand it back to you.
Mark Smith.
I am looking forward to seeing the former XM especially Franklin and I assume you will be there both days and many thanks for the tip off Mark!Apparently the bottom of the campsite has a railway line running alongside it and every morning an oil tanker train runs along it at 03-30 and makes a hell of a racket!! So if you're not a insomniac trainspotter you might want to pitch up at the other end.
With regards,
Matthew T.
Regassing would be difficult as it needs a decent sized gas bottle, and of course valves.Aerodynamica wrote:Anyone going to be bringing a sphere pressure tester and/or re gassing gear?
I could bring a pressure tester along, though attendance isn't guaranteed, but Sunday is looking good so far.
