Update on this car. It is now safely tucked away in my Mum's barn on a farm in North Wales until such time I can get around to putting it back on the road legally.
Car drives well enough, but no boost, not had time to investigate. Has a noisy tensioner and belts due for change. Needs some welding along sills. Interior is in reasonable condition except for a big hole cut in the roof lining in the centre where a DVD player was fitted. There is a lot of oil sprayed in the engine bay especially around the air filter/battery area.
SPotted on Linkedin FREE 2.5TD Estate in Kent/Surry border
Re: SPotted on Linkedin FREE 2.5TD Estate in Kent/Surry bord
For the no boost issue, check the pipe to the MAP sensor on the bulkhead.
