Re: ANOTHER 24v Update
Post by citroenxm » Wed Jun 27, 2012 8:23 pm
Ok.. back to the topic... Another S1 24v Update..
Managed to find an hour last night, and made a start on cleaning the rear up for welding...
Patch piece "sitting" in place.
Passenger side isnt half as bad and still has pleanty of soild metal to weld to. As for drivers side.. as and when I start...
Post by MTXM » Thu Jun 28, 2012 11:12 am
Well done Paul, she's coming along! With regards, Matthew T.
Post by citroenxm » Thu Jun 28, 2012 11:32 am
Yes but slowly.. im convinced now i will not have her ready for iccr at least but gonna try damm hard for cxm though....
Post by Dieselman » Thu Jun 28, 2012 4:46 pm
citroenxm wrote:Yes but slowly.. im convinced now i qill not have her ready for iccr at least but gonna try damm hard for cxm though....
Crickey, I'd forgotten about that, need to get a shift on, once I can.
Post by Dean » Thu Jun 28, 2012 6:09 pm
you need to stop sitting around and get a move on Will :lol:
Post by citroenxm » Thu Jun 28, 2012 6:13 pm
At least you got any welding to do like mine... ive got to adress two other areas in the floor too yet as well as a fuel leak behind the rear head...
Post by Dieselman » Thu Jun 28, 2012 7:41 pm
Dean wrote:you need to stop sitting around and get a move on Will :lol:
I'm itching to.
citroenxm wrote:At least you got any welding to do like mine...
Fortunately I welded the rear member the w/e before being hit. Good timing or what? Mrs Dm took it for test the next Saturday morning while I was lying in Hosp.
Got to get the priorities right... :lol:
Post by Dean » Thu Jun 28, 2012 9:21 pm
I'm itching to.
I can well imagine!
Post by citroenxm » Tue Jul 17, 2012 9:06 pm
Well, over the last few days, ive managed a bit more, as well as getting Vince's new toy done..
Ive completed the passenger side welding at the rear subframe mount..
Ive also had the subframe mounts cleaned and protected too...
Ive also tonight removed the Air Con compressor to access a Fuel Leak on a rubber hose.
After removing the hose I found it has gone brittle and hard, and it had a tiny split.
So im on the look out for a piece of high heat resistant fuel line..
Thats all for now!
Post by citroenxm » Sat Jul 28, 2012 12:27 pm
Well, we have achived it!!
We have gone from this:
to this:
Subframe back on, wheels on, exhaust on and spare wheel carrier on!!
Now, next little bit is a patch needed immediatly below the middle pillar on the inner sill area... right next to the fuel pipes!! :shock: :shock: :o :o :o
But we are winning now!
