Re: ANOTHER 24v Update
Post by citroenxm » Fri Mar 23, 2012 8:39 pm
Ive a 1995 M reg Xantia that is also rear end ROTTON... awfully!!
Post by citroenxm » Fri Mar 23, 2012 8:44 pm
After the rust issue above, the resto does carry on... Got the rocker masked and first coat of paint...
Progress continues... :-)
Post by Dieselman » Sat Mar 24, 2012 6:43 pm
Which 24v is this Paul, the one on the road or the other one that needs work anyway?
Post by citroenxm » Sat Mar 24, 2012 6:49 pm
hi will.. its my own h reg one.the one i had at rallies year before last..... not the k reg one.. that one is worse..
steelcityuk
Post by steelcityuk » Mon Mar 26, 2012 9:38 am
Those covers have come up a treat.
I hope the welding goes well, I've never tackled anything really rotten but I'd guess that unless it's cut back to solid metal it'll burn through really easily and spatter badly.
Keep up the good work, those 24V PRVs are something really special, I still remember that quick trip around the block at Wetherby.
Steve.
XM 2.1 SED K Plate - RP5876
Scenic 1.5 dCi 100
Gone -
Scenic 1.9 dCi 130 FAP
Prius T Spirit
XM S2 TCT Exclusive Hatch LPG
XM S2 2.5 VSX Estate
XM S2 2.1 VSX Hatch
Xantia 110 HDi Exclusive
Pug 405 GTX TD
Post by MTXM » Mon Mar 26, 2012 12:46 pm
Very sorry to hear about the rust issues Paul and I hope you manage to sort her out soon! My 24v needs a bit of further welding on the front offside cill against the wing with the bottom of the wing looking very frail as usual. I notice you are leaving the moulded strips exposed on your rocker cover that will look quite jazzy! With regard, Matthew T.
Post by citroenxm » Tue May 29, 2012 7:59 pm
Well, got the 24v Subframe off this evening to see the full extent of what to do...
I have been presented with this:
The worse side is the off side...
Post by robert_e_smart » Tue May 29, 2012 8:22 pm
You are lucky to have got the subframe off without damaging any off the rotten shell.
Good luck with the repairs! Cut and Shut anyone?
Post by citroenxm » Tue May 29, 2012 8:25 pm
surprisingly robert.. all the bolt threads were nice and clean and they all came out without a fight!
ill be cutting metal out of a W reg xantia thats here waiting to go...
Post by Dieselman » Tue May 29, 2012 8:37 pm
Definitely a bit flakey there Paul, but not insurmountable.
