Come over from .com!
Re: Come over from .com!
Yours is still on a single electrovalve and switching into sport on driver demand, unlike later ones (1994) which have two valves and the Sport switch just alters the parameters of when to switch.
As a matter of interest does yours have the aluminium inlet manifold and an EGR valve, or still the plastic intake and no EGR valve.
Confusingly the earlier one of mine has the aluminium manifold and an EGR valve, the slightly later one has a plastic manifold and no valve.
One possibility is that it has had a replacement engine, but I think that's unlikely, more likely is that Auto's didn't have EGR at first. I need to check the engine number.
hmm mine seems to be firmer in manual mode than auto mode?Dieselman wrote:Yours is still on a single electrovalve and switching into sport on driver demand, unlike later ones (1994) which have two valves and the Sport switch just alters the parameters of when to switch.
mine has aluminium intake manifold and EGR valve. and it's all original! also my xm a manual.
My previous Citroen's:
93' XM 2.1 turdo D manual saloon,
BX 19RD estate x2,
Visa 17RD,
AX 1.0 highlight,
BX 14 preview,
DTR turbo saloon,
AX 11RE,
Xantia 2.0i LX,
Xsara vtr coupe (bug eye)
BX 17txd turbo saloon.
BX 19RD estate x2,
Visa 17RD,
AX 1.0 highlight,
BX 14 preview,
DTR turbo saloon,
AX 11RE,
Xantia 2.0i LX,
Hi Simon, A warm welcome to the Club and I too like the colour, which is definitely 'Platinum', ie. light grey, rather than the dark blue anthracite or silicon greys available around that time. In my collection I have three Platinums, a V6 12v (1990), V6 24v (1991) and 2.0sei (1993). I understand your preference for the original alloy design, although the wobbly webs are correct for the period. If the car is a true Series 1.5 it will have hydractive 2 suspension fitted, for which the manual settings will be 'Normal' and 'Sport', rather than 'Auto' and 'Sport'. With regards, Matthew T.
S1.5s are Hydractive 1 with improoved computer parameters arent they, and a SINGLE electro valve.. The car is a 1993 K reg, which is the same as my V6 sei, and she has Hydractive 1 with H3 computer, which is the better setup..
Hydractive two wasn't along till M reg S2 cars... I could be wrong though.
The system on S1.5 cars IS the most reliable setup!
Hi Paul,
I have hydractive 2 ('Normal' and 'Sport') on my two late Series 1 (1993) 2.0sei turbos.
With regards,
Matthew T.
With regards,
Matthew T.
There were s1.5's with H2 suspension, i think H2 came in around R.P5900 ish
Is the change in wording the way to tell H1 from H2?? Or has your 1993 SEi got two electro valves Mathew?
My 1993 K reg V6 sei doesn't have two - from what I remember that is..
once thanks guys for your kind comments. but what have i started! i've checked my hydractive ecu and all it says from what could see 'valeo hydractive asc or a5c'? my button says 'auto' and 'sport'..............
i do however have a loose blue connector with a blanking plug into it in the ecu box?
cheers.
cheers.
BX 19RD estate x2,
Visa 17RD,
AX 1.0 highlight,
BX 14 preview,
DTR turbo saloon,
AX 11RE,
Xantia 2.0i LX,
BX 19RD estate x2,
Visa 17RD,
AX 1.0 highlight,
BX 14 preview,
DTR turbo saloon,
AX 11RE,
Xantia 2.0i LX,
Simon the blue connector is the hydractive diagnostic socket, green will be engine management (not for you though) white is ABS, there is another but i cant remember that.
o.k cool, thanks.Dean wrote:Simon the blue connector is the hydractive diagnostic socket, green will be engine management (not for you though) white is ABS, there is another but i cant remember that.
simon.
BX 19RD estate x2,
Visa 17RD,
AX 1.0 highlight,
BX 14 preview,
DTR turbo saloon,
AX 11RE,
Xantia 2.0i LX,
BX 19RD estate x2,
Visa 17RD,
AX 1.0 highlight,
BX 14 preview,
DTR turbo saloon,
AX 11RE,
Xantia 2.0i LX,
