Just got an XM! ['92 TDi Estate, J71 MCW]
gwolfski
Orga / RP numbers: 5623
Re: Just got an XM! ['92 TDi Estate, J71 MCW]
Post by gwolfski » Tue Apr 30, 2024 1:15 pm
Sad day, got the update from the garage. Rotten. Floors where the subframe joins are rotted out. Rot all the way up from the jacking points, strut(?) towers can be pierced with a screwdriver. Garage deems it "not worth it" to repair. It's a shame because the only other major problems are the hydraulic leak and a small engine oil leak.
Post by Dieselman » Wed May 01, 2024 6:28 am
Pretty normal stuff on an Xm, but you have to decide whether to either fix it yourself, pay for it to be done, dispose of, or break it down.
Flegmaatikko
Orga / RP numbers: 5082
Post by Flegmaatikko » Wed May 01, 2024 10:48 am
Do you have any pics of how bad it is? Breaks are so rare that I would personally try to save them.
-90 XM V6 ERT
gwolfski
Post by gwolfski » Wed May 01, 2024 11:35 am
Don't have the skills for the first, got little budget for the second, I'd like to avoid the 3rd and 4th at all costs.
I'll be getting some once I go back down to collect it
I think I'll end up putting it in dry storage so it doesn't get worse, and start putting *more* money aside.
Post by Dieselman » Thu May 02, 2024 6:49 am
If you have some space, buy a welder and some metal and start your journey.
gwolfski
Post by gwolfski » Thu May 02, 2024 11:32 am
I actually do have an old arc welder, but pretty much anyone I talked to said you need a mig for car panels. I'll look into it again, I do even have another victim- I mean, project car that I could practice on (lada niva if curious)
Post by Dieselman » Fri May 03, 2024 6:48 am
Car panels can be welded using arc if you are patient and use very low current, but Mig is much, much, easier.
Many years ago, I welded new sills and floors into a very rotten Mini 1275GT using a cheap buzz-box Arc welder. It was strong enough to pass an MOT and probably saved my life two days later, when my friend crashed it heavily. The collapsing of the front stopped when it reached the new metal.
You could convert the Arc to Tig by adding a gas delivery kit.
gwolfski
Post by gwolfski » Sat Jun 01, 2024 6:16 pm
All the garages around me are booked for months, so the rust work will need to wait (unless I manage to get some practice in with the welder). I might as well try to get some of the electrical working.
A quick question about brakes: If I disconnect (and cap off) the rear brake line at that 8-pipe union on the firewall, will this cause issues (other than no rear brakes, which leak anyway)? I'd like to be able to move the car around without loosing fluid all the time.
Is the door and window control module(s) in under the dash on the driver's side, or somewhere else? I've read the sunroof can be closed manually, but can it be opened that way too?
Post by Dieselman » Sun Jun 02, 2024 7:08 am
The four pipe union has a feed from the main circuit, a feed to the front brakes, a feed from the rear suspension and a feed to the rear brakes.
If your leak is only when the brakes are actually being applied and from the rear pipework, then capping off the appropriate union will leave the rest of the system functioning, including front brakes.
Check the route of the pipe and cap off the appropriate union.
The central locking module is under the r/h dashboard, the window one shot relay is in the drivers door card.
The remote plip receiver is in the interior lights console.
The sunroof can be operated by a manual crank inserted into the drive gear. The crank should be under the mat in the glovebox, but any correct allen key will do.
There is a rod to release the drive clutch from the motor, buried in the sunroof wiring. see attachment.
gwolfski
Post by gwolfski » Sun Jun 09, 2024 11:46 pm
capped off the rear brakes (unfortunately, the fittings had corroded to "vice grips" size and took a fair bit of work to get loose), replaced the worst tire with the spare (the cradle came down very easily).
I took it out for a drive, the first time in years that is has reached speeds of 100+. I have some nice, straight national roads (I believe the equivalent of A roads) that are empty at 2 am. Done about 40 kms with no issues
The bumpy roads seem to have improved the electrical connections, as a bunch of dash lights started working again, although the fuel gauge is now intermittent. And no backlights.
The suspension kept going into hard mode, but I think I have traced that to a loose battery terminal.
The acceleration is very smooth, you almost don't notice how fast it is getting.
one of the sidelight's not working. I changed the bulb, to no avail, but I suspect the house-style terminal block and crimped wires just behind it could be causing bad connections.
Replaced a burnt out brake light, and there is so much tape and splicing in there. I can only guess it is for the trailer socket. The tail lights are also collecting water inside them, which is rather not ideal.
Something shorted out in the left mirror, with the motor going crazy, and some poorly connected wires smoking. Due to this, the adjustment mechanism cabling has been disconnected with a pair of snips. The glass has alreafy fallen off prior, and the plastic cogs in the mechanism appeared damaged. It seems the unit has been condemned for replacement for years.
The fog lights on my toyota are more powerful than the low beams of the XM. I have noticed the lens to be extremely yellow, so I hope cleaning them up will make a noticable difference
