I've joined the XM lifestyle
Re: I've joined the XM lifestyle
Yea si and sei used a different setup.. a sensor in the head or on the td on the top hose outlet housing.. coupled with three relays.
- Orga / RP numbers: 4777
ahmadmarfy wrote: ↑Wed Aug 23, 2023 11:26 amcitroenxm wrote: ↑Wed Aug 23, 2023 9:35 amAre you in the UK? I took a front end off a base uk 2.1td with manual fan control .. ie it had the thermo sensor in the radiator as it was a non ac or temperature controlled car.ahmadmarfy wrote: ↑Wed Aug 23, 2023 9:28 amWhen you say random locks, what random ones would you be referring to?
Also I'm missing my radiator fan loom, the cable connection is missing and a switch might be needed with it. Single Fan setup is the one I need.
I might add to the list, by needing headlights and and spare seats in romana ?
Yes im based in the UK, Leicester, East Midlands. Sounds interesting, based on information that i have heard i think the 2.0si has a slightly different setup from all the other cars but i am more than willing to take a look at everything.
i'll upload a few images in the evening of my car.
I've decided, I'll take the whole front end off you. Let me know what else i can take from you?
What else do you want?
So the list:
- Lock Set (maybe)
- WHEEL BRACE AND CRADLE (YES)
- Front end (YES)
- Middle silencer - exhaust (???)
- Romana Quilted seats (???)
- Back Boot Glass (???)
- Lock Set (maybe)
- Front end (YES)
By back boot glass do you mean the inner one thats hinged on the inner roof..? You will need to add captive nuts in the roof, the holes are.already pressed for them, the hinges to bolt the roof .. I need to weigh up what ive got left of the hinge sets.
You do need a cradle for the wheel brace? That lives under the bonnet on the.drivers side strut area..
Romania seats remains are accounted for sorry.
Exhaust sections. I've mainly only got td bits which ill need for my one.
Yes the inner glass that is hinged to the roof. It was supposed to be there, but surprisingly it was missing. I'll take the cradle and brace please yes.
no worries about the seats and the exhaust.
So the list:
- Lock Set (maybe)
- Front end (YES)
- Middle silencer - exhaust (No)
- Romana Quilted seats (Myth)
- Back Boot Glass (need to count hinges)
So the list:
- Lock Set (maybe)
- Front end (YES)
I've got the hinges already in my car, due it not being a base car.
Any spare lock even if broken, or no key, could be useful for supplying relevant pins to re-key a lock to use. Make the lock fit the available key.ahmadmarfy wrote: ↑Wed Aug 23, 2023 9:28 amWhen you say random locks, what random ones would you be referring to?
ooo interesting that's quite cool.
- Orga / RP numbers: 8032
I know of a 1992 2.0si with single fan front panel, which is for breaking.
I'm not sure if the fan loom is still there but will have a look if needed. I've also got an inner rear screen with fixings if you're still looking for one.
Cheers,
Jon
Cheers,
Jon
90 XM 2.0 Si manual RP4930 ETB Platinum
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
72 D Super 5 Black
