Ecu n bits
- Orga / RP numbers: 4937
Re: Ecu n bits
Other half wants a day out too, but is busy on the 20th, so 27th if that's still ok?
Re: Ecu n bits
Yup ok 27th no problem..
- Orga / RP numbers: 8032
Re: Ecu n bits
Some interesting suggestions there Will, thank you. It is an efi model with original injectors and pump etc so conversion to a modern system would make sense. Original Bosch parts are not cheap, that's if you can even find them.Dieselman wrote: ↑Sun Mar 12, 2023 8:46 amIs this to be a carburettor to injection project, or is the car already fuel injected?
If a conversion, I would pick one of the injection systems from either a 1.9Bx, or 2.0i Xm, probably the Magnetti Marelli G5, as that is distributorless.
As long as the system has a knock sensor the timing should advance the timing until the start of knock is detected then hold it just back from there.
Though if you fit a Motronic 3.1, it automatically uses the Lambda sensor feedback as mixture regulation.
The cold start auxiliary air valves can seize up and I wondered about using an XM one, maybe just operated by a switch.
90 XM 2.0 Si manual RP4930 ETB Platinum
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
72 D Super 5 Black
