Purchase in an American XM desert - am I brave enough?
bump_drft
Re: Purchase in an American XM desert - am I brave enough?
Post by bump_drft » Fri May 03, 2024 2:48 pm
Ha, I think that's the car I bought.
It is indeed very basic, I'm a bit sad about the lack of hydractive, but I do like that there's very little to go wrong.
I just drove it across the country. JAX to New Orleans, where it stayed for 8 or 9 months, I did some very basic refreshing (I'm not mechanically inclined). I just finished a drive across the country and now it's in Los Angeles, CA for a visit to a specialist, whenever he gets back to me.
Car is fine other than some weird starting issues and an exhaust leak that I can't seem to fix. It needs an accumulator sphere but always stands up fine and levels.
It's a superb car for New Orleans, but less at home in the wide open desert freeways--the engine is buzzy and busy at 85+, so your speed is limited.
1990 2.0i 5-speed
Located in New Orleans, USA
Post by Dieselman » Mon May 06, 2024 6:47 am
The exhaust leak might be the manifold is cracked, 2.0 Atmo engines do tend to do that.
The engine may be revving relatively high at 85 mph, but is well within it's operating range. The car is capable of about 125mph, so at 100mph is using 50% of its power output...~65Bhp.
New engine mounts may make engine noise less intrusive.
Good to hear you are stretching it's legs. Do you find it comfortable?
bump_drft
Post by bump_drft » Mon May 06, 2024 9:59 pm
It is lovely, lazy, and comfortable, perfect for New Orleans' destroyed roads. I put a new (used) header on it, but it is still noisy and getting worse. I suspect the shop did something wrong on the install. I did give them new bolts and gaskets. I have a really great shop here in Los Angeles that's going to go over it top to bottom.
1990 2.0i 5-speed
Post by Dieselman » Sun Jun 02, 2024 1:12 pm
For info, the 3.0 SEI Auto in the linked to article is now for sale from Euroaisianauto in Kansas.
https://www.carscoops.com/2018/06/want- ... nsylvania/
https://www.euroasianauto.com/cars-for- ... n&model=XM
It would have been a nicer deal off BAT, but ...
Interestingly, this car has the wrong steering wheel fitted, with Rp 5204 it is a 1991 car, so should have a single spoke wheel. I suspect someone wanted a leather covered wheel so exchanged it.
Note the earlier lights switch. In the engine bay it will have multipole Gnd connections.
Here is the BaT listing from 2018.
https://bringatrailer.com/listing/1992-citroen-xm/
The same model car back in 2010.
https://karakullake.blogspot.com/2010/1 ... en-xm.html
Jan
XM newbie
Post by Jan » Mon Sep 09, 2024 1:11 am
HI in Atlanta
I have the same car 1999 xm exclusive v6/24 valve here in Maine.
I imported it and got it from Holland . Used to be an embassy car in France.
Got some leaks I am trying to deal with in the front and I hope to get there as I dont think anyone here can help me much.
Post by Dieselman » Mon Sep 09, 2024 6:23 am
There's nothing you can't fix yourself on an Xm.
Where are the leaks?
I assume your car has an automatic gearbox, which will be the ZF4HP-20. They are known to b short lived due to the filter being inaccessible inside the gearbox, so eventually blocks. Keep changing the Atf regularly to reduce contamination.
