Introduction to Kevin
Kevin
Re: Introduction to Kevin
Yes still in decent order
OK recover it and keep it. It is only screwed into the front panel. 4 or 6 screws..
Kevin
Hi. Did you manage to sort out those dash parts?
Kevin
Sorry to chase. Did you manage to find those 3 dash parts. Best kevin
Yes Kevin.
We have the upper part around speedo..and heater vents
Main front panel with dash switches and you have the panel for the lcd displays..
Lower panel on passenger side to go under the dash..
Id you look at the door on the panel from under the dash there's a twist catch you turn to open the lid. Pull it out of its place and keep that too. The one I have just needs that bit.
Kevin
Glove box?
Would you be able to arrange to send those parts to my daughter in Aberwystwyth? I will get her to transfer the cost of these parts to you also.
Thanks
Kevin
Thanks
Kevin
Yes glove box too...
Aberystwyth wow.. Yes no problem at all. I could almost deliver them myself.. I'm only on Anglesey...
I'll see if I can find a box big enough to put it all in..
I've. Sent you a. Pm Kevin.
Saraphi
- Orga / RP numbers: 6834
Hi Kevin,
I'm Rex with an XM in Chiang Mai.
I'll Pm you now!
I'll Pm you now!
1995 XM S2 2.0i 16v - but with lots if Y3 bits
1995 Xantia 2.0 Exclusive
Saraphi
Quick report - Kevin is an old friend and was a member of Classic Cars of Lanna when he lived in this area. We met up for a quick chat when he was passing through Chiang Mai about 10 days ago. Hope to see more of him now we are back into touch again.
You make it sound like Kevin is Your long lost perfect cousin.
