Wanted display citroen xm y4 reference 6155L8
Xmforever
Orga / RP numbers: Cj7682
Post by Xmforever »
Hello I am looking for and buying a display for my Citroen XM 2.5 td year 1998 is necessary, in good condition and works 100% the original citroen reference for the display is:
6155L8
Thanks
Re: Wanted display citroen xm y4 reference 6155L8
have you tried opening it and cleaning up the ribbon conduct lines to lcd screeen.. and making the contact squeeze stronger.. that's useually what makes them fail.
Post by White Exec »
If you search the forum for Dot Matrix Repair, Matrix Display Repair, etc., there are some good repair guides, using the conductive rubber strip.
Guessing that your problem is missing pixels, or display in Klingon.
