Hello Chaps....new owner
Re: Hello Chaps....new owner
If tightened up first start with engine shake will soon centralise it all up..
That IS good to know
Were you fitting from above, or below?
I've never had a problem when fitting from below.
I agree with Paul, the joint will self align.
From below....I think a lot depends on bolt length (thread)....so some kits will be easy and others will be a pain in the A (like mine )
Didn't someone recently write something about preventing the (special) bolt head from rotating?
I only have vague recollections of this job from ancient XUD9 work.
Just found this diagram in Peter Russek Diesel...
Shows the same manifold-downpipe coupling?
Moving on a bit more
Turbo oil feed and drain on, intercooler pipes, injectors connected, rockets, lifters and caps on....now working out where all the @@@@@@ wires and pipes on the right side of the engine go in relation to the air-pressure pipes.
Very good.. There still isn't that many wires on the epic system. There is a air flow sensor on the inlet pipe.. Not certain if the epic pump has wires directly to it .. But the throttle sensor is over by the battery box. A before picture comes in handy here to help lol..
Next stage, timing all checked, cam locked, carrier bolted down, I even polished the bolt heads
Moving on....
After a stupid mistake by setting the timing on the crank wrong.....Belt is now on and it turns over well on a ratchet.
Next job get the engine mount on and fire it up. (fingers crossed)
Looking good...
