Re: Russ's 2.1 SED Auto
Post by Vince »
Looking good Russ :)
Ill have to give the nut oil thing a try
normantilbury
Post by normantilbury »
Hi all,
Have you tried linseed oil i used to use it on the clutches on gaming m/c's in the 60's to free them up
Norman
Post by White Exec »
Careful with linseed oil - it goes thick and claggy (varnishy) when left exposed to air. (Old-type 3-in-1 DIY oil used to do the same, eventually causing light-weight parts to seize up!)
I know many people have used it on black bumper trims with great sucess, but they use a certian type. You have to be careful of the rags you use and how you store them as they like to spontaneously combust too. :?
Vince wrote:Looking good Russ :)
A little goes along way Vince, and you need to buff it off to get rid of any excess. it will run in the rain otherwise. but works a treat and is cheap. Vaseline I use on the window trims.
I also found smooth peanut butter is good too..... particularly on the wing mirror trims.
Well this happened. ;) cough..... Number 6 ...cough cough! 8-)
It might end up champagne.......
Post by Charles M »
All that rain has shrunk the XM and washed the colour out a bit, Russ!
Well I thought it would be safer on my desk in the warm. :D
Post by Charles M »
Nice looking model though!
They are not too bad. Bit crude here and there. It joins my fleet...... :)
I am as bad as Matthew, but only in 1/18 scale. Bit cheaper!!! :lol:
Just don't ask why I need six of them...... :roll:
