CitroJim's Citroens
Re: CitroJim's Citroens
Post by CitroJim » Thu Jun 26, 2014 4:38 pm
captainhaddock wrote:It needs another topic as well, sorry Jim! :)
No need, it's a most interesting one.
Damm strange it only happens when turning one way... That to me would rule the flex plate out but then again...
I'd have originally said the diff but that’s been swapped..
Driveshafts, hubs (wheel bearings) or driveshaft intermediate bearing perhaps may be the root but they must have checked those things when swapping things..
Will be really interesting to know the final cause of the problem.
Post by xantia_v6 » Thu Jun 26, 2014 6:34 pm
When turning a corner, the mass of the torque converter puts an axial stress on the flex plate, as the converter is free to float on the shafts and bearing of the transmission.
It would be useful to know more about the onset of this case, and whether any of the work done changed the symptoms at all.
Thomac
XM newbie
Orga / RP numbers: don;t know by heart
Post by Thomac » Fri Jun 27, 2014 8:37 am
Hi Guys,
It's my XM you're talking about. Another video:
http://www.youtube.com/watch?v=-JrVH5X-n0Y
XM only makes the noise while cornering to the right. When i lift from te gas while cornering right the noise continuous. When i shut down the engine while cornering right the noise stops.
Automatic gear box is changed including torque converter, flexplate and flywheel. Noise is still the same. Later today i will pick up the car and i will have a look at the swapped parts. We wil jack the car only on the right side to see if noise will occur while runnig idle.
I will let you know the result.
Regards Tom
Post by xantia_v6 » Fri Jun 27, 2014 11:23 am
Another thing to check is excessive crankshaft end-float due to a failed crankshaft thrust bearing. At least you don't need to remove the engine to check it!
Thomac
XM newbie
Post by Thomac » Fri Jun 27, 2014 4:06 pm
We jacked up the car on the right running idle, up dow up down etc. to shake te car a lot. No sound. The flexplate that came out of the car is undamaged, no cracks, no rust. Same story for the starterwheel(dont know the name)?
So i'm getting out of idea's...
Post by CitroJim » Fri Jun 27, 2014 4:31 pm
So are we! What about Mike's thought on crankshaft endfloat?
Post by russ92xmsed » Fri Jun 27, 2014 5:03 pm
Does it have Diravi? Wouldn't be that though would it?
Post by CitroJim » Fri Jun 27, 2014 5:07 pm
russ92xmsed wrote:Does it have Diravi? Wouldn't be that though would it?
What? My C1? :lol:
Post by russ92xmsed » Fri Jun 27, 2014 6:02 pm
:lol: :lol: can you imagine, " here is our innovative back to basics city car, with one of the most advanced and technical steering systems ever put on a car"! Well it will help with parking.....
I wonder what the rattle is. Very nice car though.
By the way Jim, where's the promised pic of this C1 of yours..... ;)
Post by CitroJim » Fri Jun 27, 2014 6:11 pm
Remarkably, the C1 does have electric PAS :o Hardly needs it.
russ92xmsed wrote: I wonder what the rattle is. Very nice car though.
It's a good thought if it does have diravi Russ.
russ92xmsed wrote:By the way Jim, where's the promised pic of this C1 of yours..... ;)
Still in my camera :oops: I must put it on my webserver. No time now, about to go to my Friday karate lesson...
Tomorrow ;)
