Selling off one (or bits
Citjon
- Orga / RP numbers: 8032
Post
by Citjon » Tue Aug 27, 2024 8:28 pm
SteveLP wrote: ↑Fri Aug 16, 2024 7:41 am
Hi. On your photo the big fuses are next to the main fuse box in front of the air filter housing. It is the covers I need but you could just unscrew the lot and I'll have it.
The rear windscreen wiper nut-cover should just pull off.
If the passenger side windscreen washer bottle is there that would be nice to have too, but probably a pain to post. So maybe just the washer motors?
Other thing I'd like is the accumulator/regulator as mine is dripping from somewhere!
Thanks
Steve
I've removed the 2 single fuse covers (they were still attached to the front panel) and the washer bottle. Just need to check the pumps are still working.
Do you need the 2 folding covers for the battery connections as well?
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
SteveLP
Post
by SteveLP » Thu Aug 29, 2024 3:00 pm
Hi. I will be at Chevrons - not sure which day yet. But I can be flexible. Maybe do both if it is good weather!
Yes. The covers would be good to have too. Thanks. Steve.
Citjon
Post
by Citjon » Thu Aug 29, 2024 8:16 pm
Sunday looking likely for me. MOT is on Friday so assuming it passes I'll have Saturday for the shakedown runaround
89 CX25DTR T2
72 D Super 5 Black
Citjon
Post
by Citjon » Sat Aug 31, 2024 4:21 pm
Aerial base has been removed if still required?
89 CX25DTR T2
72 D Super 5 Black
Citjon
Post
by Citjon » Sat Aug 31, 2024 4:24 pm
SteveLP wrote: ↑Thu Aug 15, 2024 4:38 pm
Hi Jon
Could I have the covers on the Maxi fuses by the main fuse box and the plastic cover that covers the nut on rear wiper please?
Oh also the coolant expansion tank if still available!
Cheers
Steve
Hi Steve is it the bit on the end of the wiper arm or the nut etc itself you need?
89 CX25DTR T2
72 D Super 5 Black
GeorgeCarter
Post
by GeorgeCarter » Thu Sep 05, 2024 5:43 am
Have you still got the panel which goes around and between the headlamps?
Citjon
Post
by Citjon » Thu Sep 05, 2024 6:47 am
GeorgeCarter wrote: ↑Thu Sep 05, 2024 5:43 am
Yes that is still here. I've also got the S1 type available if required.
89 CX25DTR T2
72 D Super 5 Black
GeorgeCarter
Post
by GeorgeCarter » Thu Sep 05, 2024 8:14 pm
Citjon wrote: ↑Thu Sep 05, 2024 6:47 am
That's brilliant & thanks for replying.
How much would you want for them?
Citjon
Post
by Citjon » Fri Sep 06, 2024 2:52 pm
GeorgeCarter wrote: ↑Thu Sep 05, 2024 8:14 pm
I would say £20 to £30 depending on the condition
89 CX25DTR T2
72 D Super 5 Black
GeorgeCarter
Post
by GeorgeCarter » Fri Sep 06, 2024 7:03 pm
Ok, if you let me know on the S2, pls.
