Re: Paul's 2.1Sd manual K47 BAN.. On the road
Post by citroenxm » Sat May 02, 2015 9:47 pm
Staying dean. im not allowed to sell her! The boss has spoken! :lol: :D
Enjoy one that i personally put effort into restoring. A lot of time but rewarding result.
Post by Dean » Sat May 02, 2015 9:53 pm
Excellent Paul, that's good news.
Post by Dieselman » Sat May 02, 2015 9:56 pm
citroenxm wrote:Staying dean. im not allowed to sell her! The boss has spoken! :lol: :D
Sanctury.
Post by russ92xmsed » Sun May 03, 2015 10:44 am
That's great news. Considering it's future was in doubt at one point, it's certainly found a good home.
Post by citroenxm » Sun May 03, 2015 10:46 am
Done almost 3k in it already since her mot 2 months ago!!!
Post by Dieselman » Sun May 03, 2015 11:00 am
Cheap motoring.
Post by citroenxm » Sun May 03, 2015 6:42 pm
Ok. Two jobs ticked off..
I forgot to list above the noisy and weakening wiper motor..
So firstly swapped the LH display..
Steering wheel off..
This is how the display was showing..
Ideally take the cowling off from around the stalks.. a tip here.. to ease getting the top cover off remove the plugs from the two stalks.. this gives better clearance for getting the top section out..
Now remove the heater front panel.. roatry panel..
Prise out the blower speed and air direction roatrys
Remove the two black screws..
Pull the panel away the middle one will come with it. Pop out the slider lever too.
Remove the four brass torx screws..
Theres two screws under the dash holding the front from below
Remove those..
Then theres two more hidden screws behind the central display.. under the speedo cover cowling..
Remove the two blanking covers
Take the screws out.. then slightly tricky lever the front edge upwards.. carefully..
Be carefull.. it can break and has on this one.. then prise up and towards you away from the clocks..
Then the two hidden screws can be found..
Remove the vents from the centre.. theres snap clips that need prising out to allow the front half housing the three displays towards you..
Disconnect the clock and centre warning and LH display plugs and move it forwards.. theres no need to unplug the lower switchs..
The display is held in with simmilar snap clips like the heater vent section over behind the centre vents..
Remove n replace..
Ahhh thats better
Reassemble!!!
I also swapped out the wiper assey too
Scuttle trim off
Ahh theres the blighter..
Wiper arms off.. 2x 13mm nuts.. the assey is held in by 3 10mm headded bolts.. thats all
Tip.. for removing the assy from the scuttle area.. its a slight fiddle but if you pop off the arm for the nearside wiper it will all come out with a wiggle here n there..
Refit... then press the arm back on.. reasemble
Two down..
Wheel bearing, glove box, and plipper and she be virtually perfect..
Post by Dean » Sun May 03, 2015 6:47 pm
Excellent Paul, you should split these and put them in the self help section.
She is coming along now.
Post by citroenxm » Sun May 03, 2015 6:49 pm
Yes actually after i reviewed the post it looked quite good..
Its a pita to do all this on a mobile but managed to do it so far...
Post by Vince » Mon May 04, 2015 8:05 am
Great instructional post Paul.
I need to remove my display panel again and replace it with the one I got last time I was at yours. I will follow this to help me along :P
