Fusebox Replacement
edelweiss
Re: Fusebox Replacement
Post by edelweiss » Wed Feb 08, 2017 8:16 am
It didn't seem to do anything untoward and it was taken from an identical car so hopefully I didn't need anything up. Only difference is I have noticed the anti sink device working better!
Sent from my SM-J320FN using Tapatalk
Post by White Exec » Wed Feb 08, 2017 8:29 am
edelweiss wrote:. . . and it was taken from an identical car . . .
Are you sure about this?
Not just model type, but RP number and equipment level? Serial/version number on the two boards?
edelweiss
Post by edelweiss » Fri Feb 10, 2017 11:08 am
"As a next step, if you have a multimeter, it would be very interesting to see what voltage you get on the fuse F5."
11.7 with ignition on, 5.2 with ignition off and key out...
djg
Orga / RP numbers: 7903
Post by djg » Sat Feb 11, 2017 12:17 am
That's far from OK but will explain why you have a dimly lit light after switching off.
Could you disconnect that timer box temporarily? I wouldn't be surprised if that cured most of your problems. This timer is fed directly from your F5 and it seems to have a short of some sorts between its feed and output (faulty switching transistors, that is).
Without the timer you won't have internal lighting (unless you have a replacement at hand) but all the rest could return to normal.
Bye,
Gábor
djg
Post by djg » Sat Feb 11, 2017 1:18 pm
As another idea, if the timer will be the culprit and you don't have a replacement, it would be relatively easy to remove the internals and replace it with a single connection to earth. That way you could regain some (but not all) of the switching functions of the interior lighting but without the dimming. It just switches off at once.
Bye,
Gábor
hwolter
XM newbie
Orga / RP numbers: CL 7702
Post by hwolter » Sun Apr 02, 2017 10:33 pm
I have the same problem with my 98 XM LHD 3LV24, namely that after winter storage, the interior lights won't turn off.
I don't have the other side effects of the original poster. My problem seems intermittent; sometime cycling the right front window turns the dimmed lights off.
What this problem ~ever~ fully resolved?
My suspicion is that it is some sense switch on the door, its wiring, or a faulty dimming relay.
Best regards,
Heinz, (from Canada!)
djg
Post by djg » Mon Apr 03, 2017 11:55 am
If you can trigger it with the door, then that would be the first to check. All four switches work in parallel to send a ground to the timer relay.
Bye,
Gábor
edelweiss
Post by edelweiss » Tue Apr 04, 2017 9:31 am
this is still ongoing...
is this blue box on the bottom left of this pic the timer you are talking about?
djg
Post by djg » Tue Apr 04, 2017 6:47 pm
Blue, under glovebox, according to the diagram. Should be. It has a 7-pin brown connector, hasn't it?
Bye,
Gábor
Post by White Exec » Tue Apr 04, 2017 7:20 pm
The blue one in the LH corner of your photo is on the main fuseboard, and is rear screen wiper timer.
The lighting timer (#961, and possibly blue) is plugged into a 7-pin brown connector, and on a RHD car could well be on the driver's side.
