breaking for parts, 94 diesel estate 2088cc
juu37
XM newbie
Re: breaking for parts, 94 diesel estate 2088cc
Post by juu37 »
Great - my reflector is not bad so I will compare. But it is the lens part that I really need, following a minor dink. I have e-mailed you and will PM, (new to this forum stuff).
southerner
Post by southerner »
Sorry I not been around just of late, mums dementia is getting a lot worse less time spent on the car, any way still have a lot of spare parts still going same conditions applying make an offer I more than likely will take it.
Hi..
Is this an auto? Im after a wiring loom from the car... on the Passenger side. It runs from in the car behind the dash under the LHM tank and battery box to the front behind the drivers headlight..
NEEDS to be an Auto though...
southerner
Yes its an Auto, it has the round block and not the square block, I got some of the loom out all ready still need to spend time on getting the main loom out from under the dash board to under the bonnet.
Actually, if this is a 1994 model, its not the engine loom I need, it will be the main huge dash loom across the whole of the car under the dash board..
Did this car have the DOT MATRIX read out on the LH display, or was it the Diagram of the car?
southerner
Let me check on the display
Ok great. Im a bit stuck with mine now. As I destroyed the Base Cars original Loom, so im sookered.
Ideally I want to up spec the L reg D. So it needs to be the higher spec car. One way to tell, the Blue plug that connects to the LH display is a double decker plug in blue, the lower spec its a single connection...
southerner
It the Diagram of the car type
Its an L reg mark 1 xm
Daaam, thats the same as I have now....
Sorry. Back to plan X (other places) ... thanks for checking.
southerner
lol plan x it is
