XM V6 Sei finally going for restoration
Stickfinger
Re: XM V6 Sei finally going for restoration
Post by Stickfinger » Mon Jul 11, 2022 1:07 pm
Water bath first.....flat after a day will show as it is a lot of air loss. It is possible to seal wheels (and engine blocks) in a vacuum chamber using a bath of ultra thin resin but that would cost more than a set of 2nd hand ones/restoration.
99% of the time it will be corrosion on or a nick in the rim.
Post by citroenxm » Mon Jul 11, 2022 3:38 pm
Not heard of porus alloys.. did the tyre fitters clean up the tyre edge walls.on the wheels.. where the tyre lip contacts the wheel .. if they aren't cleaned up or still have corrosion on them they won't seal well..
Post by Dieselman » Tue Jul 12, 2022 7:08 am
I'll second the tyre bead not sealing, I've had this on two Xm that have stood for years.
Remove the wheel and lay down, deflate the tyre, run some soapy water into the bead then force the bead a little, then re-inflate. Even standing on the bead can be enough to re-seat it.
If the bead really won't seal there is sealing compund available at tyre centres.
dcz1643
Post by dcz1643 » Wed Jul 13, 2022 5:15 am
Thanks for the reply’s guys. My thoughts are similar to yours, E.G. the beads are not sealing. Peter is taking the wheels to another guy, who is going to take the tyres off again and see what he can do. I think the issue is (correct me if I’m wrong) those particular alloys are quite rare, so sourcing another set would be hard. They actually look in decent condition, so I think I am better off getting the original set, sorted. Cheers…Derek
Derek
1990 Citroen XM V6 SEi (SORN)
1997 Ford Explorer V6
2011 Jaguar XF Diesel Sport
1974 Triumph Spitfire 1300
Post by citroenxm » Wed Jul 13, 2022 12:37 pm
They pop up now n again. If they are the ones with the larger centre caps. I have a spare cap in stock. used but I think one or even 2 of the cap feet have broken off.
Post by Dieselman » Thu Jul 14, 2022 6:51 am
I would be very surprised if the wheels are faulty. I have acquired a couple of sets of these in poor condition, where the tyres wouldn't hold air, mainly due to being deflated for a long time.
It's always the bead seal that is the problem, and so far, always been sorted with the soapy water trick.
A good test is to lay the wheel flat and run soapy water into the bead, then leave it for half an hour. Bubbles indicate a weep.
dcz1643
Post by dcz1643 » Fri Jul 15, 2022 1:35 pm
Thanks, That’s great but I do have all 4 centre caps, I know where to call me if I lose any though👍
Derek
dcz1643
Post by dcz1643 » Fri Jul 15, 2022 1:40 pm
Thanks for all of the replies, as people predicted, the alloys are NOT porous at all😁 A different man has today removed the tyres from the rims, cleaned and sealed the beads and put new valves in and everything is good. I am not sure what the last guy was doing, maybe trying to save money, as they are only a temporary set of tyres, to enable Pete to move the car around more easily. When it’s sorted, it will need new boots before an MOT. Cheers everyone👍
Derek
Post by Dieselman » Sat Jul 16, 2022 8:46 am
I doubt that. No tyre fitter is gooing to supply and/or fit tyres not road legal, the legal implications are too great.
I suspect the tyres were originally fitted without any tyre soap, which enables them to slip on the rim, so seat properly.
dcz1643
Post by dcz1643 » Sat Jul 16, 2022 9:05 am
I see your point, anyway the car won’t be driven on the temporary tyres. The fuel tank is being drained next, so hopefully we may soon have a running engine🤔😁
Derek
