For an S2 the radio is actually in the wrong din slot. The flap covers the din box only on S2 cars leaving the factory radio continually on display.. Another backward S2 step..Stickfinger wrote: Wed Aug 04, 2021 2:18 pmhttps://scontent.fbrs4-1.fna.fbcdn.net/ ... e=61311BCA[/img]
Hello Chaps....new owner
Re: Hello Chaps....new owner
Stickfinger
It is in the upper one on my car,,,, and atm it is staying there
On S2, there's a (sort of) choice of which of the three slots you use for a radio. The upper two are single-DIN, but only the top one has a covering flap. The cubby can be removed from there, and put in the next one down, but most radios in the top one will not allow the flap to close (unless you can unclip the fascia) which is a shame.
The bottom slot is for ashtray/cig.lighter, and covered, and could, maybe (hell, there's a lot of ,,, in this one) get used for a hidden radio.
Middle slot was the OE radio position on ours.
As you say, Paul, a backward step in keeping the valuables covered.
Stickfinger
Strange, my flap closes just fine and it is a standard single din radio
Mmm... Must investigate further.
Stickfinger
As you can see it is parked up above the radio....and it does close/open fine.
Perform a pre mot check of all testable items to be sure you don't miss anything and I will be fine.
With the radio being an aftermarket item, does it display the station in the L/h display?
Stickfinger
The Radio does not display on the l/h display
Final MoT checks does, all light, wipes, farts and clunks, cannot find anything wrong (but that is the MoT testers job not mine
O...M...G...
Fingers crossed for the test.
Stickfinger
@@@@@@@@@ typical.....just went out to warm the car up/check it starts etc......and a ABS light has come on from ignition.....wiggles the wires, still on !!!!!!!!!.....##S !
MoT in 1-1/2 hrs !
MoT in 1-1/2 hrs !
