Gold 2.0Si
Eddie nuff
Post by Eddie nuff » Mon Jul 13, 2015 12:43 pm
I will have a look at the Bio stuff if need be but the results aren't too bad as it stands. Still needs some more time in the sun but seeing as it's slinging it down . . .
Re: Gold 2.0Si
Post by Dean » Mon Jul 13, 2015 1:31 pm
extra rinse..............
Re: Gold 2.0Si
Post by MTXM » Mon Jul 13, 2015 1:58 pm
It was good to hear you have had some success with cleaning the headlining Neil. May I also dare to suggest that once in the car you will rarely look at the ceiling which is also generally in shadow!! Regards, Matthew T.
Re: Gold 2.0Si
Post by White Exec » Mon Jul 13, 2015 2:42 pm
Wearing a chauffeur's peaked cap helps... ;)
Eddie nuff
Post by Eddie nuff » Mon Jul 13, 2015 5:54 pm
I've spent enough time faffing about with this bloody thing so a wee bit longer to get it right won't hurt. Once it's in it's not coming back out!
Eddie nuff
Post by Eddie nuff » Tue Jul 14, 2015 6:01 pm
After leaving it to dry out properly it's come out very well tbh. There's three or four marks that need to be removed but it should look okay when they're done.
I need a favour. As this headlining has come out of a car with no sunroof I am going to have to make the solid aperture that enables the headlining to nestle up to the sunroof.
robert_e_smart wrote:Image
I need to know how deep this is from the headlining up to the sunroof.
Also is that a rubber(?) trim that sits around the inside of the aperture to finish it off?
Re: Gold 2.0Si
Post by citroenxm » Tue Jul 14, 2015 6:48 pm
Wow.. sterling efforts neil.. i look forward to seeing the end result..
Hat off to you for your efforts
Re: Gold 2.0Si
Post by Dieselman » Tue Jul 14, 2015 7:24 pm
I think that is Robert's photo of his G plated car.
The trim piece looks like material over foam. The depth from the flat of the roof lining to the sliding tray is 2.5cm and from the sunvisor protrusion, 3.5cm. You should be able to measure this from the underside of the sunroof cassette.
Eddie nuff
Post by Eddie nuff » Tue Jul 14, 2015 7:29 pm
Ta very much, that's just what I wanted.
And yes it is Robert's car. I used it to show what I meant.
Re: Gold 2.0Si
Post by citroenxm » Tue Jul 14, 2015 7:31 pm
Not dooing well at the moment..
Ill step down and get my coat... :oops:
