Hello Chaps....new owner
Stickfinger
Re: Hello Chaps....new owner
Post by Stickfinger » Tue Jul 20, 2021 12:32 pm
Temporary plan = get the original back on (I want the roof closed) so this is the plan.
Wire brushed (aggressively) and treated with Bilt & Hamper Hydrate-80.
I also thinned it and loaded the Hydrate-80 (20% water, it is water based anyway) into the inner edge so it penetrated by capillary action under the tray/glass covering areas that I could not reach with a brush, after an hour I used light air pressure and tilting the glass onto its edges to force it into any areas that might not have received coverage due to air-traps.
Left to dry overnight them I attacked it aggressively again with a wire bush and re-coated with Hydrate-80. Whilst this was drying all rust flakes were removed from the seal (surprised how much was in there) and this was blown out/brush clear.
Black Primer and two top coats of Satin-Black.
The next step is to prepare/clean/oil the cassette, then apply PU Adhesive to the seal and whilst that is still soft attach the glass/frame to the runners and close the roof slowly to the closed position. I hope excess PU Adhesive will "fill the voids" left after the rust was removed.
Once set I will use a fine tube nozzle to seal the top seal edge and "in-fill" the inner edge to prevent moisture ingress.
Post by citroenxm » Tue Jul 20, 2021 6:47 pm
Cassettes. Xm ones very different.. The part the glass slides into is a full.. Urrmmm.. Enclosure.. They are damm heavy to take out too..
Xantia ones.. Bearing in mind there's what 3 years between the designs in xantias favour.. The xantia glass slides back into an open space.. And therefore is a lot lighter.. Smaller.. And different but are still webasto units.
Stickfinger
Post by Stickfinger » Tue Jul 20, 2021 8:53 pm
Well that is back in and tight, will leave it overnight to let the adhesive set.
Post by White Exec » Wed Jul 21, 2021 5:26 am
Looks tidy enough.
Stickfinger
Post by Stickfinger » Wed Jul 21, 2021 8:38 pm
The sunroof works and the seal has stayed on....as a temporary result and as they say ooop narth..........that'll do fa naw
Post by White Exec » Thu Jul 22, 2021 4:17 am
. . . held on bah gum :cry:
Stickfinger
Post by Stickfinger » Thu Jul 22, 2021 1:59 pm
Total PIG of a sweaty job.....stuck together with a sealant who's strength is only known by those flying starships in the distant future !
Post by citroenxm » Thu Jul 22, 2021 2:44 pm
Am I right in thinking that's an S2 front indicator / fog lamp unit..?
Why the dismantle..?
Stickfinger
Post by Stickfinger » Thu Jul 22, 2021 4:22 pm
Non fog-lamp type.....need to convert it into one using the crappy one from the car that is dull/grey/dirty and dusty from a long time with a broken glass.
Glass removal is a massive PITA, heat and levers coupled with a worrying amount of force.
Stickfinger
Post by Stickfinger » Thu Jul 22, 2021 7:43 pm
In the "spot lamp free" unit the reflector mounts are already there.
The hole needs a threaded insert pressed/glued in so I scavenged the threaded insert and the adjuster screw.
I need to drill a hole for the adjuster screw in the bottom but thankfully the square socket is also moulded in as with the twin lamp unit.
