Breaking 2.1td Silver Exclusive series 2
rosspa
Re: Breaking 2.1td Silver Exclusive series 2
Post by rosspa »
Hi Dave,
Just wondered if you still have the sunroof? If you do, does it work and what would you want for it?
If anyone else can help, I am also looking for an emerald front n/ss wing and both rear doors.
rosspa
Post by rosspa »
Hi Dave,
Post by xantia_v6 »
MTXM wrote:A angle grinder was used to remove the sills, but it did require around 20 discs and a great deal of skill by Dave!! The cutting route was planned to avoid double and triple skin metal where possible and especially around the rear wheel arches and the other tricky sections were against the front jacking points and floor projections for the seats! Needless to say the second side was somewhat easier. I know Dave plans to remove the front hubs Paul and I am also hoping that the drive shafts and front corner-centre suspension pipes might be saved. Regards, Matthew T.
Hmmm... I am going to scrap a rust-free, undamaged LHD shell. Does anyone want the fun of recovering the whole shell or parts of it? The car is in Burgundy.
davetherave
Post by davetherave »
Sunroof has been claimed I'm afraid
Dave
(87) 2.5td Cx
(01) Gpz500s
I'd love the front section of the passenger, or drivers side in this case, sill. Little tricky it being in France!
I almost forgot to ask, is the Cruise Vaccum pump in working order?? Im looking for a good one to try and sort a non working system on an M reg exclusive up here.
The bellow and Vac pipe is good, but the pump suspect.
Is the pump unit available?
