A conversion...
Re: A conversion...
Sounds good.
Re: A conversion...
That is indeed great news Paul! With regards, Matthew T.
Re: A conversion...
Sounding good. There's a lot to be said for things that don't wobble in the flywheel department.
Thank goodness we don't have to worry about DMFs.
Re: A conversion...
However, over on FCF, with this pic, notice anything now annoying??citroenxm wrote:I fitted the solid flywheel today and am pleased to report there is pleanty of clearence between it and the block and i tried to lever the flywheel and crank pully and there is zero side to side movement from what i can see.. so im rather pleased to say the engine is fine and must be a shoddy install on the autobox somewhere..
Annoyingly, thats a crack in the sodding fly wheel!! If it rains it pours!!
Re: A conversion...
I see the crack. I wonder how that happened. There appears to be a shiny mark where the crack is, has the flywheel taken a knock?
These V6 seem a bit fragile.
Re: A conversion...
JOOI, what are the second set of teeth for (the thick square ones)?
Re: A conversion...
They are for the crank sensor to detect revoulution.White Exec wrote:JOOI, what are the second set of teeth for (the thick square ones)?
Re: A conversion...
Right.. I have some news, and its bloody good news too!
I got to the farm this evening, and did a VERY close study of the flywheel, I used my phone camera on video and with the flash on permanetly, and I LOOKED three times!
There is NO crack in this flywheel! I looked three times, then a fourth and NO there is no crack in it!!
Ive taken a video of it too, Im quite releaved. Awaiting a video upload to process so I can paste a link..
Re: A conversion...
Re: A conversion...
LOL. Cobweb crack.
