For Sale: 1990 Citroen XM 2.1 SED
Re: For Sale: 1990 Citroen XM 2.1 SED
I know the EGR valve makes access difficult, but would it be enough to stop the turbo being withdrawn the same as a Non-EGR car?
- jamescarruthers
This was done from underneath
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Previous XMs:
H656 BKJ XM 2.1 SED
Was the complete manifold removed, or the turbo unbolted from the manifold, in situ.
- jamescarruthers
Turbo unbolted from manifold I think
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Previous XMs:
H656 BKJ XM 2.1 SED
Keith10
- Orga / RP numbers: XM 2.1 TD auto hatchback RP is 6045
Hi BB Thanks for your extensive description, Is the car drive-able ie: does it all run engine/suspension etc and is it MOT'd would it get back to Shropshire on road. Also I have 3 other xm's and as you say the chrome trim is bad on all of them, common fault. would you mind to pass on the members name and link for the side stainless steel strips you mention
Best Regards
Keith
Best Regards
Keith
Brian Primmer o7812 356 431.Keith10 wrote:Hi BB Thanks for your extensive description, Is the car drive-able ie: does it all run engine/suspension etc and is it MOT'd would it get back to Shropshire on road. Also I have 3 other xm's and as you say the chrome trim is bad on all of them, common fault. would you mind to pass on the members name and link for the side stainless steel strips you mention
Best Regards
Keith
- jamescarruthers
Hi Keith,Keith10 wrote:Hi BB Thanks for your extensive description, Is the car drive-able ie: does it all run engine/suspension etc and is it MOT'd would it get back to Shropshire on road. Also I have 3 other xm's and as you say the chrome trim is bad on all of them, common fault. would you mind to pass on the members name and link for the side stainless steel strips you mention
Best Regards
Keith
I think you were interested in my car. I've decided to keep it, for now, a I ha the turbo replaced.
If you are ever near Cambridge, you are welcome to take a look at it, to see if an XM is right for you.
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Previous XMs:
H656 BKJ XM 2.1 SED
