That must be pretty quick.Dean wrote:http://www.guy-croft.com/viewtopic.php?f=5&t=2905" onclick="window.open(this.href);return false; 250bhp supercharged BX 16v, nicely done too.
A V6 24v Manual S1 Life Spared!!
Re: A V6 24v Manual S1 Life Spared!!
the thing that amazes me apart from the excellent knowledge and planning around this little project is the guy is pulling those numbers on a stock management setup, ish. damn good effort. would make a lovely drive i would think, fairly quiet on the Dyno too. 10/10 to that man.
The management unit is a Bosch MP3, iirc. That means it has full control anyway, so as long as it sees the increased air flow and the knock sensor does it's stuff, the management will be fine after a new lookup table is downloaded.
As said in the text, it just needed greater flow injectors to cope with the demand.
That's amazing. They do look good tarted up BX's.
STOP NOW YOUR OFF TOPIC!! Discuss elsewhere please..
- raynoon
- Orga / RP numbers: 6043
Getting back on topic... Have you decided what you're doing next?
Yes ray.. Finish K ban.. Which doesn't have a lot to do now.. And then start one of my own projects...
