I really don't think a Xantia strut top can be fitted to an Xm, even if the bolt holes are the same.Southerneruk wrote: Wed Jul 29, 2026 9:00 am GOPR0953.JPG
It looks like the mech at Citroën Freeborn is right it is the same shape
how about the fixing down 4 boltholes
The orientation is incorrect and I think the Xantia one is taller.
I wonder if the Xantia metal tube was used when making these Xm strut tops.
Can you please measure from the baseplate to the top of the casting, as that is all that matters.
How close to the scuttle flange is the sphere at normal and Max height settings? I would have thought with an additional 10mm height, the sphere must be touching the flange.
The differences in actual casting and rain drip cowl are immaterial. The original four dimple strut tops had straight sides, after 10 dimples was used the casting was changed to the stepped design, presumably as an easy identifier.
Has anybody reported this issue back to Meca-Place?
