Relay holders have now been removed. One is perfect and one has a couple of cracks but could still be used.
If interested I am happy to send them for £10 including postage.
1994 VSX CT auto BREAKING
Citjon
- Orga / RP numbers: 8032
Re: 1994 VSX CT auto BREAKING
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
89 CX25DTR T2
72 D Super 5 Black
Southerneruk
I have them
pemitch1701
- XM newbie
- Orga / RP numbers: RPO 7123 2.5 turbo diesel manual VSX Estate
RPO 7732 3 litre V6 automatic Exclusive hatch
Audi TT MK1 Quattro roadster
Hyundai Tucson hybrid (which I highly recommend for anyone looking for a new car) - Location: Horncastle Lincolnshire
Hi
Do you still have the front and rear left hand door locks of the central locking. Both mine are playing up.
I'm in Horncastle and can come and remove them myself if you prefer.
Cheers
Cheers
pemitch1701
- XM newbie
Oh and please could I buy the coolant header tank as well.
Southerneruk
Do have the bits between the aerial and car roof, need to be careful when removing it as an expansion peg that needs to be taken out first, you can get to that from inside the car and removing the light panel where the motor and gearing for the sunroof, remove the peg before removing the cable and undoing the nut
Citjon
Hi Paul,pemitch1701 wrote: Thu Jun 20, 2024 8:30 am Hi
Cheers
Yes I've still got these and the header tank. You are welcome to call in and remove them - please pm your contact details.
Regards,
Jon
89 CX25DTR T2
72 D Super 5 Black
89 CX25DTR T2
72 D Super 5 Black
Citjon
They should still be on the car, I'll have a lookSoutherneruk wrote: Thu Jun 20, 2024 9:52 am Do have the bits between the aerial and car roof, need to be careful when removing it as an expansion peg that needs to be taken out first, you can get to that from inside the car and removing the light panel where the motor and gearing for the sunroof, remove the peg before removing the cable and undoing the nut
89 CX25DTR T2
72 D Super 5 Black
89 CX25DTR T2
72 D Super 5 Black
Southerneruk
OK thanks just that mine as broken at expansion peg and now leaks
gwolfski
- Orga / RP numbers: 5623
Hi,
Is this an AC car? If so, and if the heater/AC control panel is still there, which style is it?
Citjon
Sorry there is no AC on this car
89 CX25DTR T2
72 D Super 5 Black
89 CX25DTR T2
72 D Super 5 Black
