That’s great news, I don’t know when but I hope to become the third XM guy at some point. Enjoy your meet up, I am sure I will see some pictures posted on the groupmaxferreira wrote: Fri Jun 17, 2022 1:03 pmHidcz1643 wrote: Fri Jun 17, 2022 7:45 amHi again, I was wondering how you got on with getting your XM sorted. Are you now running around in it? There is a group on Facebook called “Retros of Teesside” (it is a big group, worth joining) and I notice a guy has a beautiful looking blue XM. So when mine gets done, there will be 3 XM’s I’m Teesside, that we know about. Cheers Derekmaxferreira wrote: Thu May 19, 2022 9:59 amMines a grey 2.1 td auto, only been here since Aprildcz1643 wrote: Thu May 19, 2022 9:19 amI haven't seen an XM in Teesside for quite a few years, is yours on the road and what area are you in? I used to see a burgundy one around and about, is that one yours? Good to hear from you...maxferreira wrote: Mon May 16, 2022 6:55 pm Lovely looking car!
glad you're getting it restored
i notice, Teesside.....i'm also in Teesside
so, there's an another XM in Teesside, how wonderful!
Currently sitting at a garage in Thornaby awaiting repairs to start on Monday
I'm in Middlesbrough, hoping to have mine on the road around this time next week, feel free to have a drive of her, she does need some work
I'm so pleased there's another local one, should meet up and get both the Teesside XMs together, I can't see there being any others
yes it's on the road and i've been driving round in it a fair bit lately
yes indeed, i'm a member of that group, and i'm meeting him on wednesday to get them both together
i do wonder if there's any more hidden away? must be
XM V6 Sei finally going for restoration
dcz1643
Re: XM V6 Sei finally going for restoration
Derek
1990 Citroen XM V6 SEi
1997 Ford Explorer V6
1974 Triumph Spitfire 1300
2024 Explorer EV
2024 Explorer EV
maxferreira
- Orga / RP numbers: RP6043
it would be rather excellent to get all 3 of them together!dcz1643 wrote: Fri Jun 17, 2022 5:44 pmThat’s great news, I don’t know when but I hope to become the third XM guy at some point. Enjoy your meet up, I am sure I will see some pictures posted on the groupmaxferreira wrote: Fri Jun 17, 2022 1:03 pmHidcz1643 wrote: Fri Jun 17, 2022 7:45 amHi again, I was wondering how you got on with getting your XM sorted. Are you now running around in it? There is a group on Facebook called “Retros of Teesside” (it is a big group, worth joining) and I notice a guy has a beautiful looking blue XM. So when mine gets done, there will be 3 XM’s I’m Teesside, that we know about. Cheers Derekmaxferreira wrote: Thu May 19, 2022 9:59 amMines a grey 2.1 td auto, only been here since Aprildcz1643 wrote: Thu May 19, 2022 9:19 am
i do wonder if there's any more hidden away? must be![]()
At the CCC National Rally on 8-10th July.
Dereks car is in Wisbech, so he could just about push it there if the starter motor isn't done...
dcz1643
It might be a bit too heavy to pushDieselman wrote: Sat Jun 18, 2022 8:00 am At the CCC National Rally on 8-10th July.
Paul (citroenxm) is kindly supplying a replacement starter motor. So when it arrived in Wisbech, it will be fitted and then Peter will get the XM running. He can then tackle the suspension system.
I think it might be slow going, because Peter is a busy man
Derek
2024 Explorer EV
2024 Explorer EV
dcz1643
Hi All, looking for a bit of advice for my mate Pete. The starter Paul kindly provided, arrived in Wisbech and is working great. Today Pete installed it but there is still an issue with the car. The car won’t turn over on the key (correct code entered), just some dash lights go off. However, it will spin if the starter is shorted. That indicates a possible problem with the starter relay. So first question, does anyone know the location of the relay, or any other suggestions regarding the possible problem? Cheers….Derek
Derek
2024 Explorer EV
2024 Explorer EV
Try holding the key in the start position and move the gear lever from P to N..I've even just sort of pulled the lever towards R then bavk to P.. But bringing it to N will also allow starting, If the selector is out if adjustment it may not quite put the inhibit switch in the correct position when in P
The inhibit switch is on the back if the box.. I can't remember if the Autos have an additional start relay.. If so its obevof the relays behind the Headlights.
dcz1643
Many Thanks for your reply, I have sent it over to Peter. You reply makes a lot of sense....Derekcitroenxm wrote: Sun Jun 26, 2022 7:06 pm Try holding the key in the start position and move the gear lever from P to N..I've even just sort of pulled the lever towards R then bavk to P.. But bringing it to N will also allow starting, If the selector is out if adjustment it may not quite put the inhibit switch in the correct position when in P
Derek
2024 Explorer EV
2024 Explorer EV
The relay isn't a starter relay, it is the start inhibit relay. All the starter solenoid current passes through the Ign switch, as opposed to the relay making a direct battery feed.
iirc, it is the outermost relay behind the left hand headlamp.
The starter current passes through the ignition switch, then the start inhibit relay main contacts.
The relay is energised by the ignition switch sending power to the gearbox selector switch, which transfers power to the start inhibit relay coil when the selection is either Park, or Neutral, thus closing the main contacts.
The dashboard indicator should also show the selection the gearbox selector switch is making.
All the Series 1 wiring diagrams are in the, below, linked thread.
viewtopic.php?f=8&t=10268
As citroenxm says, the fault could be either the gearbox selector switch, or the start inhibit relay.
Shorting out the main contacts of the starter inhibit relay would allow the Ign switch to send power to the starter irrespective of the gearbox selection. Make sure the gearbox is in Park before trying this.
Stickfinger
Just a note:..... I had corroded wires feeding into/hidden under the relay plug/mounting bracket, only found when I dismounted the sockets/mount from the body
dcz1643
Thanks for your replies guys, very useful. I will pass all of this on to Peter and let you know what happens
Derek
2024 Explorer EV
2024 Explorer EV
