Hello Chaps....new owner
Re: Hello Chaps....new owner
If the ecu monitors boost pressure which I guess it does then possibly not in that case unlike the machicsl ones.. Up boost adust the lda on top of bosch pump and up the fuel a tiny bit..
Stickfinger
All ready to go back on now I think............phew !
Exactly that.Stickfinger wrote: ↑Tue Jun 01, 2021 8:41 amMuuuummm, interesting.
Talk to be about adjusting/checking the Turbo linkage --before-- I put it all back in the car.
As simple as this ?
In my experience there is very little /no preload set as standard.
You can just lift and replace the clevis without having to pull the linkage.
It looks ready to go back on.
Ensure the head bolt holes are cleaned out and bolts can be easily screwed in all the way by hand, then oil them when fitting the head.
Stickfinger
Getting close now...........
If you still have the option, fit the glowplugs and injectors before mounting the head.
All fuel control is electronic on the Epic system, no Lda to adjust.
Yes will I know.. This is me..
My brain bit just about works. I was refering to a complete mechical setup. One reason lucas is an Epic fail.Projects:(eventually if theres any bodywork left)
Stickfinger
I'm not sure on that one either.. As the lucas pump is low enough to change glow plugs. I think heater plugs are best changed when a bosch pump is used.. As the bosch pump sits up in design over the flatter lucas pump..
Stickfinger
Head is now on.....2 stage tightening then 180deg
I used a friends Snap on electronic t-wrench.....just set the angle and it adds it up as you go through multiple pulls then beeps when it get to 180 degrees total.
Wonderful piece of kit.
