Hiya - a new guy here
Julianw
Orga / RP numbers: 4937
Re: Hiya - a new guy here
Post by Julianw »
ul9601 wrote: Tue Mar 05, 2019 11:31 pm I might try to mod the parcel shelf to lift with the hatch though.
That would be a most worthwhile mod imo! :D
ul9601
Orga / RP numbers: don't have any
Post by ul9601 »
Very splendid and worthwhile, indeed! :) (I've been listening to the Hitchhiker's Guide to the Galaxy today...)
'91 carb'd 2.0 manual
Post by White Exec »
It will lift up with some added strings, but the holding springs underneath will need to be disabled, otherwise it won't lower again - unless you relay on the downward clout of the tailgate to do it!
The 13th window seems very much a matter of taste. The one here has had just one day's use in 21 years.
ul9601
Post by ul9601 »
White Exec wrote: Wed Mar 06, 2019 7:55 am It will lift up with some added strings, but the holding springs underneath will need to be disabled, otherwise it won't lower again - unless you relay on the downward clout of the tailgate to do it!
I didn't know there were springs - I'll have to take another look.
White Exec wrote: Wed Mar 06, 2019 7:55 am The 13th window seems very much a matter of taste. The one here has had just one day's use in 21 years.
That's pretty disappointing - It does seem like a gimmick, really, I mean how many times do you open the hatch on a trip while everyone is still inside the car? And it must really blow with rain and gale to make a difference. Also could get quite annoying if folding down the rear seats on a regular basis.
My mistake - just one 'grip' spring, in the centre of the long hinge, under a small plastic cover.
Function is to keep the flap raised when lifted. Gets tired over time; just needs a bend to work again. Do not lubricate, or it slips.
Vaguely connected, a bit of boot lighting improvement from 2014: viewtopic.php?f=8&t=5804
ul9601
Post by ul9601 »
I think my hinge spring is well knackered.
Very impressed with the brightness of the boot lighting! I have mine turned off though as I don't like bugs drawn into the interior.
PS - love the boot floor carpet!!! 8-)
ul9601
Post by ul9601 »
Julianw wrote: Tue Mar 05, 2019 9:26 pm Welcome. Is it Delage Red? ...
It's EJV - Mandarin Red.
I haven't seen other reds so can't really make comparison but do like mine.
Julianw
Post by Julianw »
Ta. More plummy than delage then, I'm guessing - delage looks a bit more 'brick red', especially under certain lights.
ul9601
Post by ul9601 »
I've had a couple of red cars other than this - one was a maroon Ford Fairmont (refer my avatar) and the other, series 1 C5, rouge lucifer, both of them I was quite fond of...
ul9601
Post by ul9601 »
Parcel shelf mod - proof of concept.
I think I'll need black string, obviously. The hinge is a bit crooked, not sure why.
