Everyday XM?
Re: Everyday XM?
Post by Dieselman » Mon Mar 28, 2016 11:50 am
nyekk wrote:If I'm not mistaken and we talk about the same item, the throttle lever position sensor on the top of the pump is part of the EGR system. It is used to determine when to open the EGR valve. I simply disconnected mine, it is not part of the pump operation.
That is correct, it went from a switch to a potentiometer. The switch only activated the valve at idle, the potentiometer allows a proportional volume of EGR at low accelerator postions.
jonathan_dyane
Re: Everyday XM?
Post by jonathan_dyane » Mon Mar 28, 2016 6:11 pm
I've fixed it.
Unfortunately assembling my pump incorrectly had damaged a lug on the spring device which transfers movement from the accelerator lever to the governor which effectively rendered it U/S.
I decided to have another shot with the Xantia pump and although I was convinced that I had fully engaged the woodruff key I'm embarrassed to say I clearly handed because this time it started and run well, and after full reassembly and a test run it runs just fine albeit performance slightly blunted which I hope turning up the fuelling may ameliorate. A good result!
Jonathan.
2004 Saab 9-5 Aero Estate
1999 Yamaha FZS 600 Fazer
1991 Kawasaki GT-550
1986 MZ ETZ 250
Re: Everyday XM?
Post by citroenxm » Mon Mar 28, 2016 6:16 pm
Fantastic Johnathan.. You now are the 2.1 TD Xantia pump Guinea Pig ... Possibly the first one on the road with a Xantia Pump...
raynoon
Orga / RP numbers: 6043
Re: Everyday XM?
Post by raynoon » Tue Mar 29, 2016 5:18 am
Hey glad you've got it sorted
Re: Everyday XM?
Post by russ92xmsed » Tue Mar 29, 2016 10:59 am
Well done. That's great news. :)
Re: Everyday XM?
Post by Dean » Tue Mar 29, 2016 5:31 pm
Thats a good result, i think the 1.9 to 2.1 pump swap has been done before on Xantia's with much success so no reason it shouldnt work on an XM, good work.
Re: Everyday XM?
Post by russ92xmsed » Tue Mar 29, 2016 6:34 pm
I thought Paul tried a 1.9 pump on an XM to see if it worked. Again it did. Of course that could be selective memory!
Re: Everyday XM?
Post by Dieselman » Tue Mar 29, 2016 7:25 pm
Any diesel pump will work, but getting the fuel delivery right will be the issue.
I suspect a Bosch pump has more than enough overhead to deliver enough fuel for 110Bhp.
Re: Everyday XM?
Post by citroenxm » Tue Mar 29, 2016 7:31 pm
I fitted one on a 2.1 td auto.. But only ever started and idled and shunted around the yard.. Not driven on the road to see how one performs.. 2.1 pump to a 1.9 i can understand... Your putting a higher power set pump on a lower power engine.
jonathan_dyane
Re: Everyday XM?
Post by jonathan_dyane » Tue Mar 29, 2016 8:18 pm
Thanks guys, I'm very pleased to be back on the road. Before I alter the fuelling I am going to advance the timing *slightly* as I think it is a touch retarded (the car is noticeably quieter, starting slightly less instantaneous and idle ever so slightly rough).
Jonathan.
1986 MZ ETZ 250
