How an XM Should be dismantled for spares....(Pg 4 onwards)
Re: A Decision to make.... Dont be shy Tell me!!!
Post by citroenxm » Thu Jun 13, 2013 6:42 pm
Well the decision is made.. she will be parts. Started at half one this afternoon when the rain had passed over at the back end. Shall work from the back forwards but remove the inside first..
I have some pictures to share. But ive not uploaded them to my hoast yet. And a suprise to accounce too..
Everything will come off this car except the rotton rear passenger door which will get stripped out..
More follows......
Post by Dieselman » Thu Jun 13, 2013 6:43 pm
Scrap cars can be returned to the road without a VIC as long as it is genuinely the same car with the registered major mechanical components. The only exceptions are Insurance category A and B, C with a VIC check and scrappage scheme cars.
My Cobalt car had been declared scrapped, but I put it back on the road.
Post by robert_e_smart » Thu Jun 13, 2013 7:27 pm
I bought a XM that was declared scrapped with DVA, and paid for a duplicate V5, and all was fine. They removed the scrap marker.
Post by citroenxm » Thu Jun 13, 2013 7:35 pm
OK OK.. I get it ... :lol: :lol: :lol: Thats ok then... I know he some V6, but thats all, and a K plater BASE model with no sunroof and no spoiler...
ANYWAY.. back to this car..
As said above, the descision is made.. Spares for the SED she will be..
Anyway, after 4 and a half hours...
I WILL be removing the talegate, because the rear heated screen is good.. got the chance to test it earlyer..
A anyway, that doesn't look like a lot done for four and a half hours work... thats because it took and hour and 15 to do THIS:
Im gonna move this to members cars (blogs) section now, as I shall be continuing documentation on this ...
Post by Dieselman » Thu Jun 13, 2013 7:37 pm
Having just bought one... :roll:
Post by citroenxm » Thu Jun 13, 2013 7:39 pm
The choice to break this car WAS NOT there then... as I hadn't seen the "Extra" holes in the Cills..
So that irrelevent to me really. The SD value is still higher then what I spent I think..
Ive also got the boot midde plastic and rear reflector to go in now
Eddie nuff
Post by Eddie nuff » Thu Jun 13, 2013 7:50 pm
Ahh, so you figured out how to do it! 8-)
Re: How a Dismantled XM should be for spares..(Pg 4 onwards)
Post by russ92xmsed » Thu Jun 13, 2013 8:00 pm
Amazing what you can find under a boot carpet....radiator, alternator, head gasket!!! :lol:
Also interesting seeing what is behind the lights on the boot door. I always thought it would be a nice idea hiding a third LED brake light in between the reversing lights. But alas there be an 'ole in the way.
Nice job getting that rear window out. Well done, bet your really chuffed. :)
It is a pity, but it is the right decision to brake it up.
Post by Vince » Thu Jun 13, 2013 9:34 pm
Once Linda is back earning again Paul ill be coming over to do a deal on some spares to bring back for the preservation and restoration of my xm ;)
Definitely interested in some of the bits you have ;) Whatever you do, try not to damage the dash display panel you have out of this one....mine needs replacing, I scratched it a while back and the r/h display is shot as you know ;)
Post by citroenxm » Thu Jun 13, 2013 9:37 pm
I have about THREE RH displays with NO bleeding etc..
If I can get the glass out without breaking them then anything else should not be a problem!!
Keep a watch to see progress. The other reason for dismantle I decided that the Old SED needs the rear subframe mounts welding, like the 24v, but they are quite good on this J reg, so, remove the subframe and cut the Box Sections out completely and treat them inside, and stick them on the SED! Better JOB done.
I also needs the near side leading edge of the wheel arch for another Project Car I have... so that will come in usefull too..
