About S2 nose cone....i like the s2 nose cone more than S1.
Led lights upgrade...they are ok for reverse lights,but where on front you're planing to install them?Day running lights into bumper or just to replace standard bulbs in side lights?
Apologies i missed the fact that you had painted your pillars....they look great
No for mine im planning an existing bulb LED upgrade across all lamps....luckily for me a friend of mine has the correct kits and id willing to install them for me. Nice bright lighting all round
I looked around considering the options and found a US supplier that seems to be all right but, actually, they're hardly road legal in Europe... Headlamps and similar are definitely out of question, they'll never work (they need different lamps, no matter what they claim, there can't be such a thing as replacement LED for H1 and the others). Interior lighting is OK, reverse is OK, you need a new flasher relay for indicators.
Bye,
Gábor
