Breaking S1 2.1SD
Re: Breaking S1 2.1SD
I did that but found the outer two nuts seized due to water ingress into the crossmember. The subframe bolts undo OK but I'll have the rubber bearers off as well as iirc they are no longer available from Citroen.
They are listed on the S2 screen:I'll have the rubber bearers off as well as iirc they are no longer available from Citroen.
0000513175 JOINT SET 155,81 GBP 186,97 GBP 186,97 GBP
At this price I would hope that is a complete set for the whole rear subframe, with both pairs of front and rear mounts.
vive la difference
Hi Everyone
I just thought i would add to this thread that i have just completely dismantled a S1 TD12V (LHD) MANUEL all parts now stored under cover in my barn Parts can be shipped to the UK as i have a friend travelling across on a weekly basis, or you could take a short break and collect! Bring your XM back to the land of its birth!
regards Brian
regards Brian
citroen xm S1 v6
Range Rover P38 4.6 HSE
Alfa Romeo 147
Alfa Romeo 147
How do you get the auto gear selector handle off, it won't come off even after removing the screw low down.
Drop the whole remote housing off will four ten mm nuts under the sound proof rubber surround auto selector cables do sieze up.. So keep it complete and drop it down....
I'm definitely having it off the car, just thought I needed the handle off first.
In case you didn't see my comment in Matthews thread, this car is rotten all the way, removed the ECU box yesterday to find the inner wing right through and the bumper support and wing tab to be none existent.
Nope it can stay complete....
If you do want to remove the selector top, you need to push the button in and rotate it anti-clockwise I think, and it will lift up off. It will avoid it getting damaged in storage, or when you are removing the whole lot from the car.
Thanks Robert, I'll try that.
Yep turn it 90 degrees then press the button and lift off, dont forget there is two grub screws holding it on, one each side.
