I have been unable to pin the flywheel and despite plenty of probing about through the aperture
behind the starter motor, I cannot find the locating hole to time/lock it in place at that end and
tried getting a bent bar into the lugs behind the crankshaft end pulley through that timing hole
and he damned bottom bolt IS tight. I tried combining the twisted bar and a hammer through
solid metal screwdriver against the starter teeth that I can see and nothing instils any confidence
in levering a two foot bar against the bolt.
Any slip and I'm swinging the bottom end around against a static camshaft and valves so I'm all
out of ideas.
Andrew
