XM 2.0i TCT by eduFX
Re: XM 2.0i TCT by eduFX
Hi eduFX
Thank you for posting the photograph record of work on your XM.
The photographs will help many of us in the future.
I was particularly interested in the last photos you posted comparing worn and new strut heads.
There seems to be a design difference with the new strut head.
Do you know the Citroen part numbers for the new strut heads you have?
Did you have to fit different rubber gaiters?
I think the apparent difference is just down to the old one having made a bid for freedom, so the protruding rubber is shorter.
While on that note. Does anyone have some ruined strut tops that could be used to fully investigate remanufacture of new ones? They might need to be completely destroyed to gain accurate measurements.
- eduFX
Eduardo Vieira
Xantia Break 2.0i TCT
Xantia ACTIVA 2.0i TCT
Xantia ACTIVA 2.0 HDi
XM 2.0i TCT
XM 3.0i V6 24V
BX 19 Sport
BX 19TRD
BX 16 RS Evasion
Aprilia RSV-R 1000
Aprilia Europa 125
XM 2.0i TCT
XM 3.0i V6 24V
BX 19 Sport
BX 19TRD
BX 16 RS Evasion
Aprilia RSV-R 1000
Aprilia Europa 125
Thanks for these pictures Eduardo, very interesting.
Yes, thanks a lot, they clearly show the construction.
It appears the lower plate and inner cone are bonded together than the cap is fitted and the inner cone then expanded to lock it in place.
Hi Dieselman
In the photo I roughly scaled the base rings that hold the gaiter in place.
The new one measures about 15% larger diameter than the old.
I realise that despite being in the same photo the lense may give different magnification but I would like to know if the actual dimensions are different.
- eduFX
Hi...the serie MK II are more longer...because that the XM MK II have a more rigid suspensionxmexclusive wrote:Hi Dieselman
eduFX
Eduardo Vieira
XM 2.0i TCT
XM 3.0i V6 24V
BX 19 Sport
BX 19TRD
BX 16 RS Evasion
Aprilia RSV-R 1000
Aprilia Europa 125
XM 2.0i TCT
XM 3.0i V6 24V
BX 19 Sport
BX 19TRD
BX 16 RS Evasion
Aprilia RSV-R 1000
Aprilia Europa 125
- citroenmad
Well i know i like pictures, but even i dont have this many of our cars!
Very detailed ...
Ill have to leave more time to go through them.
Very detailed ...
- eduFX
Eduardo Vieira
XM 2.0i TCT
XM 3.0i V6 24V
BX 19 Sport
BX 19TRD
BX 16 RS Evasion
Aprilia RSV-R 1000
Aprilia Europa 125
XM 2.0i TCT
XM 3.0i V6 24V
BX 19 Sport
BX 19TRD
BX 16 RS Evasion
Aprilia RSV-R 1000
Aprilia Europa 125
- eduFX
Eduardo Vieira
XM 2.0i TCT
XM 3.0i V6 24V
BX 19 Sport
BX 19TRD
BX 16 RS Evasion
Aprilia RSV-R 1000
Aprilia Europa 125
XM 2.0i TCT
XM 3.0i V6 24V
BX 19 Sport
BX 19TRD
BX 16 RS Evasion
Aprilia RSV-R 1000
Aprilia Europa 125
