3.0 V6-24 Project
Re: 3.0 V6-24 Project
Having read the comments in your screen-grabs reminded me that the owner I acquired the car from told me it was indeed capable of the official V-max, so Shaun isn't the only one to have given the car a good caning. 😈
I know they are. I tried mine once.. but backed off at 140 and she still wanted to go.
Jarvis_C
Post by Jarvis_C »
Amazing!
All the time I have owned this car I have thought there was some raspy exhaust sound on initial start, but couldn't detect if it was blowing, or not.
I was performing a pre-MOT check and jacked the car up using a beam as a support, when I heard the exhaust note suddenly deepen, so investigated.
The flexi section on the front pipe had broken free for about 90% of it's circumference. This had obviously been cracked previously, but hidden by the worm drive clip holdings recovering braid on.
I welded the crack back onto the collar, but the concertina metal is so thin and had holes in, it was impossible to MIG weld the single thickness pleats.
Here's where the fun started.
I wanted to get the job done quickly and as the pipes into and out of the flexi section are different sizes, rather than ordering some pipe and a flexi, decided to have a new one welded in.
This section of pipe runs from the front manifold to where the pipe humps over the front subframe. The fittings at each end are both angled, have to fit exactly and the length is critical. The manifold connection is a bolted flange, with no adjustment possible, the rear is a ball and socket, but has to fit precisely.
I marked a pair of alignment lines down the exhaust in situ and had the part made (cost...cough, cough, cough :o )
When I tried to fit the pipe did it fit.... :lol:
As the pipe had now been altered in length, measuring to get an accurate length was very challenging and required a number of fitting attempts, bolt up to front manifold and mark off, undo and bolt to exhaust and mark off, make allowance for the amount of droop and rotation, etc.
There is literally no margin for error, clearances are only 5mm.
It's one of those jobs you either need to tack the new flexi section in situ, or make a temporary jig to ensure absolute accuracy.
Incidentally, the bulge in the pipe to the left of the flexi section in the first image, is a catalytic converter.
This car was registered less than one month after the requirement to have Cats... :evil: There are two larger ones behind the subframe.
Time to get the V6-24v out for an MOT check-over...so of course, it started hailing.
Video
https://go.screenpal.com/watch/cOebjlnZMr0
Of course I had left the door open.
Generally seems good, just needed a battery installing, fitting a wheel-house mud shield and a general check over. I borrowed the mud shield from the Cobalt car that is currently resting.
This car is parked in my garage, but I've noticed an Lhm leak at the front. I put clean cardboard down to monitor if it was just some residual oil, but the card has become wet with Lhm.
I put a battery on the car, turned the starter a few times to prime the oil system, then input the code and fired it up, reversed it to create space and drove it up some ramps.
After a while I noticed the cooling fans come on and thought it was a bit premature, so squeezed the top cooling hose to find it was empty. I stopped the engine and refilled the cooling system with about 4L of coolant, at which point I was somewhat concerned a head gasket might be leaking.
I then went under the car to look at the Lhm leak and found the front Hydractive stiffness regulator was wet with fluid.
On the V6-24, due to routing of the extra exhaust, the front Hydractive stiffness regulator is fitted just behind the cooling radiator instead of under the subframe, behind the engine.
I've not captured it very well, but the complete regulator is wet, with a drip forming on the lower bolt. This indicates the oil is leaking from the sphere fitting, not a pipe union.
I also checked the main pressure regulator, finding it does have some oil on it, only at the base. This could be fluid that has blown back from the Hydractive stiffness regulator, so I wiped it and will re-check at a later date
Having lowered the car, then undone the pressure relief bolt before switching off, I tried to unscrew the Hydractive sphere by hand, which was still tight.
Access is terrible but I managed to fit my tight spaces sphere removal tool and over a considerable time unscrewed it. There was residual pressure locking the sphere screw threads, which there shouldn't have been as I had performed the de-pressurisation procedure correctly.
There isn't sufficient room to withdraw the sphere completely, without removing the distributor cap, rotor arm and possibly the coil and A/c drier.
As the leak appeared to be from the top of the stiffness regulator I simply opted to replace the sphere seal. The old one did appear a little thinner and has some signs of degradation. It's possible I re installed the old seal when first re-commissioning this car and it appears it may have been pinched at some stage, before my ownership. Unless damaged, these seals rarely fail, even if re-used a number of times.
After cleaning the housing and sphere neck, I greased them both, and the seal, fitted it and screwed the sphere back on, ensuring the seal stayed in position. It's not possible to see the seal when fitting the sphere, so I went under the car before final tightening and took an image.
Greasing the sphere flange stops corrosion and reduces friction to the point spheres can readily be unscrewed in future.
As the car was on ramps I decided to look into why the Hydractive sphere hadn't fully depressurised when the system pressure was released. That indicates the electrovalve hadn't remained open long enough for the sphere to empty.
As the car was now fully low, access was poor, additionally the electrovalve cover was bent causing it to be very awkward to remove. There are three 10mm headed bolts to undo, the rear one has a loose nut inside the plate, so a spanner was needed also.
Bent plate.
I parted the electrovalve electrical connector, finding it appeared clean, but cleaned with contact cleaner and greased it before refitting.
I checked the electrovalve was functioning by opening and closing a door, then feeling and listening to the electrovalve until it switched off with a healthy clunk.
I then refitted the metal plate, which I had cleaned and re-formed appropriately.
I ran the engine again and quickly noticed coolant dripping off the belt end of it.
I switched off to investigate and saw coolant running out of the water pump weep hole, which in context, is good news.
The front of car was up on ramps, with the rear sticking out of the garage. I needed to run the engine to check the suspension was working properly, which appeared to be fine, but then it did what V6-24 do best...ran out of petrol...
I had about 1 litre in a can, which was just enough to get it going again and off the ramps.
I checked the cardboard for LHM drips and found it was clean.
I then checked the coolant header tank and found it was empty.
The water pump is completely invisible, located under the engine mounting casting, which is bolted to the side of the engine.
To access the pump I disconnected the Ecu's, unclipped the relays from the front of the Ecu box, unbolted the Gnd wire, placed the Ecu loom on top of the engine and removed the Ecu box.
I needed to remove the engine mount so required access under the car to support the engine, at which point I found the car was too low to allow my low lift jack under the sump.
I jacked the car up by the subframe and pushed wheel dollies under the front tyres, then I was able to pass the jack under the corner of the sump.
I don't like supporting engines under the sump, but needs must.
With the engine supported I unbolted the engine mounting link casting and the mount from the chassis rail.
To be able to remove the engine mounting casting I had to slacken the water pump/Ac drive belt.
The tensioner roller has an 11mm lock-nut at the inner side and the tensioner screw is round the back of the casting. Access is very awkward, but a swivelling ratchet spanner works.
it might have been easier if I had parted the engine loom connector earlier, as I had to do this to remove the mounting casting.
To part the connector, lubricate, then unscrew the locking ring.
I undid the four fixings holding the mounting casting on. Three are bolts, one is a socket. The lower two bolts have to stay in the mounting as there isn't sufficient room by the chassis rail to be able to remove them.
To remove the casting the lower bolts jam it in position until the engine is raised as high as it can be. Jack the engine up and wiggle the casting out.
As I intend to replace both drive belts, I needed to, and could now access the alternator belt tensioner.
The lock-nut is visible here, the tensioner screw is on the end of the bracket, behind the radiator. Again a swivel ratchet spanner gave access.
Once the mounting casting is off I then undid the four bolts holding the pump unit on and pried it off the pipes. It was very stuck onto the O rings and I needed to use a long pry bar and spray in lubricant wherever I could access.
Access is poor as it is located in the Vee, under the intake manifold. I want to avoid removing the intake manifold, if possible as that is quite a bit of work and means acquiring new seals and gaskets.
The pump fits on one steel pipe, one cast aluminium duct, with extension tube and into the cylinder head outlet behind the thermostat, so four O rings to replace.
I started cleaning out the Vee and the O ring sockets, then supported the engine from the rear lifting eye and the alternator bracket.
I needed to suck the spilt coolant and dirt out of the Vee of the engine and do have a wet/dry vacuum cleaner, but it's for domestic use, so I didn't want to use it for this.
I have a workshop vacuum cleaner, so made up a tank to catch the liquid and dirt, by sticking a hose and the vacuum cleaner nozzle into the tank, then taping the joint to seal it.
It worked pretty well, really I should have used a larger diameter tank spigot, plus larger bore and shorter hose, for greater suction.
I then cleaned up as much of the dirt as I practically could, which revealed the engine number location. As this is impossible to see with the engine built up I read and checked the engine number is correct against the registration document: it is. 8-)
Having removed the top radiator hose from the water outlet spigot, I cleaned the spigot up using mild acid and a small wire brush, then reconnected it and acquired new O rings for the pump. I cleaned and lubricated the spigots using silicone grease and slipped the O rings on and pushed the extension tube into it's casting under the intake manifold.
I didn't take note of the extension tube O rings, though the larger ports are 39mm minor diameter, 45.5mm major dia and from memory about 4mm O ring wall thickness.
The smaller O rings are 23.5 * 3.5mm internal, which fits the steel water pipe under the manifold perfectly, but the pump thermostat spigot groove is 26mm dia, so it's a tighter fit. Both cast internal ports these fit into are 29.5mm dia.
Having cleaned te pipes and ports, then greased the O rings and the ports they slide into I pushed the pump into position and it slipped onto the unions under the intake manifold readily.
I wanted to ensure the pump wasn't snagging on the engine block, as it has projections underneath.
I placed the three pump securing bolts just to hold it in position until the pump was properly located, once all the O rings fully seated.
There is no bolt near the thermostat outlet and this proved a real challenge to push into position, due to the O ring seemingly being too thick.
the spigot groove is 26mm dia, the O ring is 3.5mm thick and the port is 29.5mm diameter. Allowing for the wall thickness of the O ring to be slightly reduced, due to stretching it to 26mm internal dia, it still has an external dia of approx 32mm.
I think the O ring should be 25.5 * 2.5mm internal, which would give an outside diameter of 30.5mm, so the correct squish to allow it to compress into the port.
To squeeze the O ring into the port I used two blocks of wood and a crow-bar to apply firm pressure to the thermostat housing, until it slipped in. Don't force it, allow the O ring time to compress, otherwise it will be trapped and tear.
I installed the thermostat, ensuring the wax capsule was facing the hot water from the engine and the jiggle pin was uppermost, then refitted the outer cover and hose.
This was a new thermostat when I recommissioned the car, fitted in 2019, or later and has only done a few miles, so didn't need replacement.
I had purchased a new water pump/Ac drive belt, but having waited for delivery it has come through incorrect. It should be 5PK 1455mm, the nearest size I could readily obtain was 1453mm, which has come through as 1435mm, so too short.
As I'm working only from above, without a new belt I cant fully rebuild the engine mount, so cleaned up the fastenings, lubricated with anti-seize and fitted the mount casting. Don't forget to install the lower casting bolts into it before attempting to fit it to the engine, as there is insufficient clearance by the chassis rail to install them with the casting in position.
I test fitted the old belt to see if one can be installed with the casting in place.
There is barely any clearance between the water pump pulley and mounting casting, but a belt can be squeezed through the gap.
I noted some scratched paint, two small rust blisters and some flaking paint where the engine mount and coolant header tank reside, so rubbed it down and applied two coats of primer and one black top coat.
After primer.
Two coats of black top coat on and dried
It was time to install the new 5PK-1455 (I obtained a 5PK1453) water-pump/Ac drive belt. First loop it round the crank pulley and post it up through the engine mounting casting, then twist it sideways and slip it through the gap by the water pump pulley. This took considerable effort as the gap is tight and I couldn't see as it is covered by the casting.
With the tensioner fully relaxed the belt wouldn't pass round the A/c compressor as it had ridden up onto the water pump pulley outer flanges.
Using a small mirror and right angled pick I was able to place the belt into the water-pump pulley grooves, which gave sufficient slack to mount it.
Due to the engine being supported by an over-head bar and chained to the engine lifting ring, after tightening the belt tensioner I couldn't tighten the belt tensioner lock-nut. I did remember to do this after fitting the engine mount and removing the support bar.
Installing the 5PK-850 alternator drive belt was next, which was also very awkward as the coolant hose obscures view and there is no space.
I slacked the alternator tensioner as much as possible, looped the belt behind the hose and onto the alternator pulley, then placed it onto the top of the crank pulley, ensuring it was properly seated in the grooves, then reached down the gap with a thin wooden stick and pushed it onto the lower section of the pulley.
Tightening the tensioner was awkward, but possible using a swivel ratchet spanner. The issue is the tensioner bolt is out of sight and facing the radiator, with only tight access.
The tensioner screw head is under the end of the alternator support bracket. I'm not sure it would be visible from underneath either as the subframe is in the way.
I fitted the rubber engine mount and the upper casting. I tried to install the casting with the fuel pipes still connected, which was a mistake as it chafed the fuel feed pipe. I disconnected the fuel pipes, installed the casting, cut back the damaged fuel pipe and re-installed them. I had installed new pipes when re-commissioning the car in 2019.
With the engine mount bolted together I removed the engine support bar and chains, tightened the A/c belt tensioner lock-nut and fitted the engine loom connector to the upper engine support casting, ensuring the loom protection wire was in position, to protect the wiring loom from the belt.
I fitted the upper engine torque link and the wiring loom clip, then the coolant header tank.
As this is an all aluminium engine and access is tight, I ensured I used grease, or anti-seize compound on all threaded fasteners and adjusters, to ensure easy operation/future removal.
