My Citroen XM 3.0 PR-Vestige
normanlindley
Huddersfield
Re: My Citroen XM Prestige
My local parts supplier supplied me with the comma LHM for £5 a litre just before Christmas.
Norman
Norman
Huddersfield Has no sunroof
Amazon small print covers restricted material and delivery location.
At final check out the item will be refused if the material or the seller cause delivery refusal.
Off mainland UK restriction is noted as a sellers option.
Try an order Dean.
Try an order Dean.
I was once told by a Millers Oils Technical Rep. that all LHM is re-branded Total, as it is a low volume product, so not worth making their own.
Just found 5 ltrs of lhm for £26 delivered which is good.
Hydrau
Pics are back on line and I have a leak on one of the front strut returns, new return ordered. Tick times are holding steady when warm at 1min 30.
Just cleaning the inside of all six headlight units at the moment, they have been dirty ever since I bought them.
Hydrau
It's all a bit shiny in there Dean...
mds141
- Orga / RP numbers: 8542
I was thinking the same thing.
Mark Smith.
1997 Honda Firestorm.
Wow, very smart.
I see an imposter part for a Series 1...
mds141
Dipstick?
Mark Smith.
Its years of going out and stroking it gives a shine like that!
Theres a few imposters in that engine bay now, one mk1 which was specific to the 24v only and later mk2 engines, 3 that i can think of are from a mk2, then there is the ignition component layout which has been changed around with the re wire to put things in a more sensible location.
Trying to source a hydraulic pump pulley cover which was standard for the ani sink pumps of mk2 but seems rare on the MK1 pumps.
