2 * 2.1 SD
Re: 2 * 2.1 SD
I carried on de-rusting the boot strengthening bracket and all was going well until rain stopped play...both physically and metaphorically, when my mini engraver tool burned out.
The way these work is they are a solenoid with a plunger hammering a tungsten pin. The frequency is simply the mains A.C. frequency, so at 50Hz, the plunger vibrates forwards and backwards 50 times per second, or 3,000 percussions per minute, 6,000 times per minute for both stokes as rated by the manufacturer.
I had noticed it becomes very hot after a only a short time operating, as it's not really meant to be used continuously.
I only need slight depth of percussion so had been using it on settings 1, 1.5 and occasionally 2, out of 5.
Only when I looked inside did I realise why running on low settings makes no significant difference to the power consumption and heat generated The solenoid core is a split core and the control is a mechanical one, which varies the distance the split part of the core is from the main part.
This does reduce the magnetic flux, but the coil is still being fed by unlimited current.
This one was rated at 24Wh and the only replacement I can obtain immediately is 35Wh, so possibly worse, so I have ordered two more rated at 13Wh as well.
As far as rust removal goes using a percussion engraver (not rotary grinder) is very slow, but the single point really is the best method as it shatters and vibrates the crystalline rust particles.
I find the best method is to flood the area with clean acid at which point any rust particles are very visible, then dig into the rust with either the engraver tip, or a pin attached to the engraver tip (I have a safety pin bent to shape to wrap around the tip). The rust is soon seen to be dissolving into the acid.
Once the acid pool is saturated with rust wipe clean and then dab clean with a acid wetted paper towel and start again. Do not re-apply fresh acid unless the area has been cleaned, otherwise the supply of acid becomes contaminated and causes flash rust.
For final cleaning I use a paper towel soaked in acid squeezed against the area, thus using hydraulic action to flush out any ferric corrosion particles, then a good dab and scrub with a fresh towel to dry it before any flash rust can form.
I have the left boot floor to wheel-house bracket nearly rust free. There are a few spots on the very left edge and the section on the raised section to the right of the large hole.
I moved onto the right side and found a patch creeping under the seam sealer, so dug out the sealer and wire brushed that section and the other small areas.
As you can see, wire brushing is not anywhere near as effective as the engraver, due to skipping over the pits.
I do have a bottle of Bilt Hamber Hydrate 80, rust converter, but believe that rust removal is better than simply converting the upper surface. I suspect it is Phosphoric acid, which can cause issues due to the outer surface being electrically charged, so doesn't create strong paint adhesion, without physical removal...which rather negates the point of the product.
Re: 2 * 2.1 SD
I bought a new Dremel brand engraver and it works well, without becoming hot.
A bit more progress. The left side strengthener is now fully de-rusted, I also went back over the previous left side bits with more acid.
I then started on the right side where there was a rust bubble that spread under the seam sealer. I'm using a pin to reach down into the corner of the seam and it nearly fully cleared.
Re: 2 * 2.1 SD
The right side piece is now fully clear and the strengthening plate also.
I also cleaned the rear and side bolt tie sections, which both had rust, due to being stressed by the bolts.
I've moved onto a couple of spots on the upper left side and have some more work to do on the right side where the ventilation exit grille is mounted.
Re: 2 * 2.1 SD
I vacuumed the boot out, especially the seams to be sealed, degreased with Isopropanol alcohol, masked the sides for a neater finish and squeezed seam sealer in, filling all crevices, then added more to build up the seal.
It's imperative to keep water out of seams, as corrosion there is difficult to rectify.
While then dried I carried on using acid on any other rusty areas and went back over all the previous ones again. I then sanded any high points down with 400 grit W&D paper, to reduce the risk of sharp points breaking through the paint and also to key the metal.
I noticed there is some shaling of the primer, so scrubbed a loose paint with a wire brush, sanded, then cleaned. After cleaning with Isopropanol, I painted two coats of primer.
Being a blue car, you can clearly see where the colour coat is only over spray and even that runs out, leaving most of the boot area just in primer.
I'm not painting the complete boot area as that needs more time, however it might be a project worth doing as those seams do seem to be affected by rust. I had previously assumed it was due to water entering from below, but now think it is from above, as the underside of this car is well painted and sealed.
Re: 2 * 2.1 SD
I had noticed a couple of areas that needed a bit more surgery with the welder.
The first was where the right hand ventilation exit duct fits in the boot wall and the second was a single penetrating spot on the left side, also near, but above the exit duct.
I found the left side single spot when de-rusting the surface rust, the pin went through. This shows a single rust bubble witness on the outside and was clearly rusted through from the inside
It's taken me a while to realise what is causing these rusty areas. The boot liner carpet is rubbing through the thin primer coat leaving bare steel, which gradually rusts.
I've always thought boot metalwork was rusting through from the outside, but it's rusting from the inside to the outside, un-noticed until there is a hole.
For the right side I cut out a piece of steel and hammer formed it to shape, then trimmed to size, and welded in.
Hammer forming is a case of make an alteration, check, make another, check, etc. These images are part way through, the final result was a very good match. Time is a factor and this is behind the boot side carpet and the vent, so not visible without dismantling.
For the left side spot, having already de-rusted the inside, I wire wheeled the outside, clamped a copper plate behind the area and welded the pin hole, then sanded flat.
Having forgotten to seam seal the new plate for the spare wheel screw, where it abuts the rear panel, I wire wheeled and further removed the paint, seam sealed and re-primed with two coats to all bare areas.
As a result of poor access, grinding the welds inside the wheel-house is not possible, so for added protection I also seam sealed the outside of the weld.
Re: 2 * 2.1 SD
Two coats of mixed top coat onto the boot areas that had been primed. This is not a complete re-paint as that would need more time than I have at present, to strip out the seats, other linings and sound deadening material. I have painted all areas the original paint has showed signs of deterioration.
When painting the lower ventilation outlets again it occurred to me that I have no recollection of removing the plastic ducts and wondered if this may have led to water being thrown up from the rear wheels and into the fibre ducts and maybe into the grilles.
Right side duct metalwork
Left side duct metalwork
I have found a left hand plastic air puller duct, but don't have a right hand one, so am asking for one. :) Right side is P# 95292142
Left side is P# 95292143, which I do have one of and is pictured here.
I waited for the paint to dry and harden and refitted the boot seal. This was originally stuck together at the ends but kept coming off the dipped part of the flange at the top corner. It has shrunk and now it's fitted properly it is too short.
Re: 2 * 2.1 SD
As the vent ducts are the first item to be fitted, I've started making a ventilation puller duct out of some bits of plastic I have. Being trapezoidal, it's quite a complicated shape and fits in a tight space, so needs to be fairly accurate.
I'm cutting, shaping and plastic welding the parts together. There is one part that forms a reinforcement, where I have chosen to make it in two parts, forming a double thickness rib, which I have strengthened with lock wire "S" shaped inserted into the plastic.
It's definitely going to be a case of function before form, but seeing as it's out of sight behind the bumper, it doesn't matter. It presents a flat under surface to deflect any water thrown up from the rear tyres, but allows ventilation and water to drain out behind the bumper.
Initial join plastic welded together.
Lock wire S shapes embedded into the plastic using heat.
Re: 2 * 2.1 SD
I made a vent outlet from semi-rigid plastic sheet, cut and welded together. It's a case of function before form, but fits and works properly and is behind the bumper so never to be seen.
The process of making it involved a lot of cut, bend, melt, and trial and error fitting.
It finally clipped in and fits pretty well.
I welded a new nut into the bumper bracket, then scratched the new paint...
Glued both fibre ducts back together and installed those and the bumper.
I glued the rear light seals on, installed them, including additional Gnd wires, then greased and fitted the spare wheel carrier screw.
On went the rear wheel back-plates, greasing the bolt threads with anti-seize, the arch liners and wheels.
Installing the arch liners is a pain as they tend to chip and scratch the paint on the lip. Even though I used plastic sliders, it still chipped the paint in one patch, meaning I had to rub down, prime and paint it.
The wheels went on and I placed some ramps under the rear wheels to be able to set the height selector "flag" to be central when the car is at normal ride height.
I had to be ultra careful when jacking the car, to ensure I didn't damage any of the subframe paint, or bend the bottom flanges.
Re: 2 * 2.1 SD
To check for water ingress I left the boot linings out and placed separate sheets of cardboard on the boot floor.
After heavy rain, when looking through the glass I was pleased to see the card was dry.
Being aware water can run into the boot from an open tailgate I opened it carefully and saw water on the inner plastic lining, which then ran out onto the rear cross-member and into the boot.
I'm sure this is the water entry point.
Out with the lights, the light bar, the painted bar and the latch unit to check for leaks and rust. I also removed the spoiler as the plastic seals were deteriorated.
Spoiler seals. Note the metalwork is deformed from someone pulling hard on the spoiler.
Light bar seal is unstuck at one point,
Initially I could see rubbed paint from the body coloured plastic strip, which after scraping back has revealed a surface rusty patch.
I think water has been entering round all the screws for the fittings, so am cleaning, painting and sealing these.
Mrs Dieselman has cut me some rubber spoiler seals from EPDM roofing sheeting. I will add non-setting sealant when installing these permanently.
Re: 2 * 2.1 SD
Spending all day de-rusting the small patches most are done. The first, long bit, took forever, but is rust free. Microscopic movement of the plastic panel has worn through the paint allowing water in.
A bit more to do, then rub the surface rust on the inside panel.
