Re: Pauls 1991 V6 24v Manual ...
Post by White Exec » Tue Mar 29, 2016 6:48 am
These are a terrific tool for filling awkward 'boxes/diffs etc., and topping up from below.
Completely dismantle for easy cleaning.
Capacity 1 litre.
Can also be used for completely emtying the LHM reservoir.
Post by MTXM » Tue Mar 29, 2016 11:17 am
I was sorry to hear you have found another hole Paul and behind the front wheel arches does seem to be quite a common problem area due to the jacking point next door and cavity formed. In relation to the gearbox I assume you tried to drain the oil before removing the drive shaft and none appeared? The refill/top up is quite a simple operation and the smaller bottles of gear oil usually come with an integral spout/tube. I can confirm that the filler plug you need to remove is against the end cover, accessed behind the wheel arch liner (see diagram attached) and just add more oil until it starts to flow back out! Regards, Matthew T.
Post by citroenxm » Tue Mar 29, 2016 12:17 pm
Ahhhh as simple as that.. Thats rather a low filling area.. You are right i did just remove the shaft and nowt came out..
Panicked a bit.. Scarse gearbox but i do have a spare though its no reason to encourage premature failiure...
Post by MTXM » Tue Mar 29, 2016 2:08 pm
There is more of the box below the level of the filler/ top up plug that does not show on the illustration Paul and it is quite a simple operation! If you have the Haynes manual to hand that should confirm the procedure. I am not sure about the manual box, but with the auto some oil is lost when removing the shafts, although obviously not all! I strongly recommend fully draining and replacing the oil that I have done on all of my cars. Regards, Matthew T.
Post by Dieselman » Tue Mar 29, 2016 5:58 pm
That plug is the gearbox drain plug, which is not the lowest drain plug, tat is ont eh differential housing.
The fill plug is a hex drive taper fit plug, 3/4 up the front side of the gearbox. It is easily accesible with either a bottle with pipe or a funnel with hose attached. iirc, you can't fill until the oil comes out,t at is too full and will wreck the clutch (i've seen that done on a BX). I was called in to replace the clutch again as it was a brand new clutch.
Drain the box and refil with 1.85 litres.
Unfortunately the low oil level indicates a leak, so expect to lose some once the box is full. It will be the driveshaft seals are worn out.
Post by citroenxm » Tue Mar 29, 2016 6:04 pm
Yes im aware no oil is a leak... I need to see which shaft oil is leaking..
Loosing the will to care at the moment..
Post by Dieselman » Tue Mar 29, 2016 6:09 pm
You drive it over, I'll take it off your hands. Don't bother washing it...
Can't say fairer than that.
Post by MTXM » Tue Mar 29, 2016 7:25 pm
That plug is the gearbox drain plug, which is not the lowest drain plug, tat is on the differential housing.
On my diagram I highlighted the filler/level plug that actually has a square inset drive Will and there are two hexagonal plugs underneath the box for draining. In refilling or topping up oil is added slowly, ideally using a 1ltr bottle with integral plastic tube, while any excess can simply be allowed to drain away. If there is a leak from a drive shaft seal it should be fairly obvious and it might just be gradual loss over time and that the level has never been checked before! Regards, Matthew T.
Post by citroenxm » Tue Mar 29, 2016 7:32 pm
Dieselman wrote:You drive it over, I'll take it off your hands. Don't bother washing it...
And you can pay for it too!! I wont give her away. I know what id like.. Im not that easy Will... Nice try.. :lol:
Post by Dieselman » Tue Mar 29, 2016 7:38 pm
MTXM wrote: On my diagram I highlighted the filler/level plug that actually has a square inset drive Will and there are two hexagonal plugs underneath the box for draining. .
Apologies if I am wrong, Matthew.
Does that engine still use the ME5T gearbox? The fill plug you marked, is in a completely different location to the other ME5T gearboxes.
