My XM 2.5 TD
Xoán
Orga / RP numbers: 8416
Re: My XM 2.5 TD
Post by Xoán » Fri Nov 06, 2020 11:59 am
Dieselman wrote:
Fri Nov 06, 2020 6:43 am
1e trick?
There's a way you can start any XM, Xantia, ZX, Saxo or Peugeot equivalent without the code. It's a 30s work. Can't publish here, we don't want our XMs to be stolen all day around :?
2000 XM 2.5 TD Blue Mauritius.
Previous: 1993 XM 2.1D Grey.
Xoán
Re: My XM 2.5 TD
Post by Xoán » Fri Nov 06, 2020 12:01 pm
White Exec wrote:
Fri Nov 06, 2020 7:22 am
When you say the ECU "has been reverted to standard again", what was done to it earlier?
When failure ECU was modified by a specialist to bypass the immo, an IC was replaced. Didn't work.
Xoán
Re: My XM 2.5 TD
Post by Xoán » Fri Nov 06, 2020 12:02 pm
Diagbox didn't read the codes :evil:
Re: My XM 2.5 TD
Post by Dieselman » Sat Nov 07, 2020 7:06 am
Try using a blink code reader.
Re: My XM 2.5 TD
Post by xmexclusive » Sat Nov 07, 2020 9:52 am
Try an ECU reset to factory or an original (unaltered) one with a known code.
The fault is almost certainly not the ECU.
