I've been lurking, Time to say Hello
Saraphi
Orga / RP numbers: 6834
Re: I've been lurking, Time to say Hello
Post by Saraphi » Fri Mar 01, 2019 10:17 am
Thanks Guys, This will be invaluable to my auto guru/electrician when we come to replace this wretched panel. Last few days have been spent doing the equivalent of a full service and replacing anything that needed bringing up to snuff. Actually the only replacements have been the track rod ends, other than that it's good to go. When I left J&N Autos at lunch time they were just taking her off to the land transport office to complete registration. Every time a vehicle changes hands here it is physically examined to ensure its what the book says it is, that it still has the same engine and no added turbos or whatever and that any accessories are legally acceptable (Colonel Bogie horns & the like are banned, for example)
1995 XM S2 2.0i 16v - but with lots if Y3 bits
1995 Xantia 2.0 Exclusive
Post by White Exec » Fri Mar 01, 2019 10:37 am
The XM has a splendid pair of French Horns, so you''ll be ok there. ;)
djg
Orga / RP numbers: 7903
Post by djg » Fri Mar 01, 2019 11:36 am
Chris,
partly. I don't remove 5. I just pull it a little bit forward (just as much as the steering wheel in the outmost position allows, no forcing or flexing at all) and reach behind. That's enough for me to get the units out. I only removed the full 5 once in my life because I needed to patch a hole in it (previous owner put a tow hitch telltale there). I have since replaced it with a perfect one (and moved the telltale to a lower position, to the part of the lower shroud that stays in place, using a proper LED socket).
Bye,
Gábor
Saraphi
Post by Saraphi » Sat Mar 02, 2019 2:30 am
Great Post Chris
Andrew Preview will be sorely missed. Still think of 'Get me to the Church on Time' whenever his name is mentioned
and the verbal Hoffnung -Oh memories, memories
