WANTED V6-24v parts required.
Re: WANTED V6-24v parts required.
Post by MTXM » Sat Jul 15, 2017 7:15 am
The last time I had this problem I simply refixed the lug with a screw from the inside that worked well! Regards, Matthew T.
Post by Dieselman » Sat Jul 15, 2017 8:48 am
MTXM wrote:The last time I had this problem I simply refixed the lug with a screw from the inside that worked well! Regards, Matthew T.
That's what I will do.
They break off becasue the front bolt rusts into the captive nut, so people pull the box up. At least on a V6, a misalligned box doesn't rub on anything mechanical, unlike other variants that have the hydro pump mounted very close.
Post by Dieselman » Tue Jul 18, 2017 9:49 pm
Wanted.
V6 hydro pump tensioner bolt set.
I wondered why the belt was slipping so slacked off the pivot bolt...and the pump nearly fell off. Bodged it with a regular nut and bolt for now.
Post by citroenxm » Wed Jul 19, 2017 12:17 pm
What preciesly are you wanting Will im not sure i understand..
Post by Dieselman » Wed Jul 19, 2017 12:21 pm
The long bolt with a threaded hole through it for the tensioner adjuster bolt.
This is the bolt at the rear side of the pump bracket, not the pivot bolt.
Post by Dean » Wed Jul 19, 2017 3:04 pm
Must be a V6 one, all the others I have seen use a shorter threaded stud.
Post by Dieselman » Wed Jul 19, 2017 8:05 pm
Wanted.
Spring clip for the throttle pot connector. This one is a wire clip, whereas all the others are side gripping clips.
Post by White Exec » Wed Jul 19, 2017 9:12 pm
Someone give this man a spare car . . . :D
Post by MTXM » Thu Jul 20, 2017 9:31 am
May I suggest that when a 'complete' list of parts needed is prepared you could call in and see us Will and it would also be possible to look over our two examples! With regards, Matthew T.
Post by Dieselman » Thu Jul 20, 2017 12:23 pm
I'll bring a tow truck.
