Is your G reg car an SE spec mathew??MTXM wrote:Not quite every 'G' reg. car Paul as my 12v auto has a factory sunroof! I also thought even early UK 'i' and 'd' spec cars had sunroofs and they were only omitted on late S2?Any G reg model bar sed or sei should have the aftermarket fitted unit as sed or sei had them as standard in uk only base and i or base d or sd being without
With regards,
Matthew T.
Sunroof cassettes
Re: Sunroof cassettes
I think all very early UK cars had post factory sunroofs Will regardless of spec and all my cars are 'se' or equivalent Paul! With regards, Matthew T.
So then Mathew as they are SE they will have factory sunroofs then and not aftermarket.. as i said above. Its only base i and si models that got the after market roofs and different head linings..
I have seen aftermarket sunroofs in two very early 'G' reg. 2.0sei Paul and I think Mark & Jacquis' olympic blue 3.0sei also had one! As I recall Citroen UK thought the XM would not sell without a sunroof here and they were retro fitted across the range. Regards, Matthew T.
That was my understanding that all early UK cars had aftermarket sunroofs fitted.MTXM wrote:I have seen aftermarket sunroofs in two very early 'G' reg. 2.0sei Paul and I think Mark & Jacquis' olympic blue 3.0sei also had one! As I recall Citroen UK thought the XM would not sell without a sunroof here and they were retro fitted across the range. Regards, Matthew T.
- raynoon
- Orga / RP numbers: 6043
My G reg SED has a standard sunroof, made 13th March 1990
I think most aftermarket sunroofs are on late 1989 production cars Ray, including the gold 2.0i owned by Neil! Regards, Matthew T.
