Xm 2.1 s2 parts for sale.
Re: Xm 2.1 s2 parts for sale.
You're twisting my arm...
messerschmitt owner
done! I'll dig them out. Poor Russ (has anyone asked him yet?) - I will be at home all day and if I'm not at home I'll only be on a tip run - first one is bright and early with the rubbish from inside.
messerschmitt owner
At least one complete set of door seals. Window seal split as soon as I touched it so no joy there.
messerschmitt owner
Have the correct black box for the working key fob.
Any ABS sensor leads?
Blue (Teves) or Green (Bendix).
Cut off close to the sensor would be fine and with both plug and socket the other end.
That's what happened to mine.messerschmitt owner wrote:At least one complete set of door seals. Window seal split as soon as I touched it so no joy there.
I may have misled you re the door seals. The seals i want are the neoprene seals attached to the door, not the car body seals.
messerschmitt owner
too late for any seals on the doors. And the abs sensors are on the stub axles. I'm not sure about leads. Probably too late as I chopped the front end off this morning. Two runs made to the tip already. Car is also a convertible pick up at moment. TOmorrow it will re-enact the scene from Day of the Jackal!
Are the sills worth saving?
messerschmitt owner
only the part that Russ specifically asked for ages ago. It'll be getting cut out tomorrow. The main reason she met her maker was (after the bump in the garden) the fact that the nearside sill was rotten through. When I chopped the nearside b post and shoogled it to take it off, the sill gave way. She's already been welded numerous times on the sills (front and patches)Dieselman wrote:Are the sills worth saving?
- raynoon
- Orga / RP numbers: 6043
Any news from Russ?
[/url]
