Przem's 2.5 TD Black/Exc (1996) - first steps into XMs world
Pshemsky
Re: Przem's 2.5 TD Black/Exc (1996) - first steps into XMs w
Post by Pshemsky » Wed Jul 06, 2016 4:22 pm
Unfortunately car is still in garage. Sunroof seal comes apart and I'm desperately looking for replacement part. Leaving my car in that garage was a big mistake in first place. Total waste of time and money. I want to sort it out asap and just forget about whole thing :|
Ok...back to subject. Any advise?
Sent from my C6903 using Tapatalk
Prem
XM 3.0 Exclusive (2000)
Gone with the wind...
Xantia 2.0 HDI (1999)
C5 2.0 HDI (2003)
XM 2.5 TD (1996)
Xantia 2.0 HDI (2000)
raynoon
Orga / RP numbers: 6043
Post by raynoon » Wed Jul 06, 2016 6:37 pm
Have you tried ringing other Citroen dealers around the North West?
Pshemsky
Post by Pshemsky » Wed Jul 06, 2016 7:28 pm
Ray usually they checking stock in different branches. I've tried even abroad, Chevronics, Citropro and few other eBay sellers who sold me some citroens parts in past :/
I was told that there's place where I can order a seal and they can make it for me from example (original seal) and that will be my next move.
If still unsuccessful I'll start considering some temporary solution and then replace it with solid roof.
Prem
C5 2.0 HDI (2003)
XM 2.5 TD (1996)
Post by Dieselman » Wed Jul 06, 2016 9:08 pm
The sunroof is a Webasto-Huliez brand, so I would check Webasto dealers.
Pshemsky
Post by Pshemsky » Sun Jul 17, 2016 12:05 pm
OK sunroof seems to be alright now. At least one problem out of my head. But yesterday new problem started - rear window heather not working. Buttons light won't come on and both fuses (F33 and F3) are ok. Now its time to start my search about this issue. Anyone got some quick tips or checks which I can do to find reason/solution for this problem?
Prem
C5 2.0 HDI (2003)
XM 2.5 TD (1996)
alexm
Post by alexm » Sun Jul 17, 2016 5:02 pm
Check the button,maybe some wire is untached, and what you need for window heater in summer [emoji1] .
raynoon
Post by raynoon » Sun Jul 17, 2016 7:48 pm
Check the elements in the window carefully, they can wear off
Post by citroenxm » Sun Jul 17, 2016 8:00 pm
NEITHER
Check the wires between the Boot Lid and Roof!! Broken wires in the Grommets is gonna be incredable likely!!
Post by xantia_v6 » Sun Jul 17, 2016 8:15 pm
Neither of the above suggestions will explain the lack of warning light will they?
Pshemsky
Post by Pshemsky » Sun Jul 17, 2016 9:53 pm
I'll do checks tomorrow guys (at work atm). Just wandering which way in the car frame wire for that screen heather going? Is there any chance that wire loom been damaged during the sunroof replacement. Its been in and out few times so if loom is nearby it could be damaged during that job. Is it possible?
Prem
C5 2.0 HDI (2003)
XM 2.5 TD (1996)
